Front arm ball joints
Hi there I've recently fitted 2 new ball joints and they have gone after a month or two. Is there anything that could be causing them to go easier? Knackered hubs? Anything like that maybe?
Thanks!
 Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
check the locating hole in the hub is not oval
are the pinch bolts tight?
Second what cully said. I had to change my whole hub for this reason...
If it's not that could it be anything else?
(31-05-2014, 01:18 PM)BenDturbo1 Wrote: If it's not that could it be anything else?
i guess if tracking is way out it won't help, did you buy silly cheap ones? . .Smile
I've had tracking done, checked the hubs and they don't look the best so gonna get some new hubs and ball joints! Would I benefit from changing them to the gti6 ones as I'm changing them? And they were quite cheap so gonna buy abit dearer ones cause you pay for what you get? Smile
  fitting a front suspension ball joint impotentials 3 3,429 29-10-2016, 05:46 PM
  dummy cv joints pug306driver 10 4,626 28-09-2016, 05:49 PM
Last Post: pug306driver
  Ball Joints? JTaylor2005 26 10,318 28-04-2016, 09:36 AM
Last Post: toseland
