Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
was looking at a transit alternator, they come in sizes up to 110amp, with a vac pump stuck on the back also..
has anyone done this if so
A. did you keep teh vac pump on the tranny alternator, or use the original and remove it
B. what alternator did you use if not hte transit one?
/Toseland
Threads: 21
3
Car Model/Spec: Stage 3 HDi
Given 5 thank(s) in 4 post(s)
Most hdis have a 150 amp alternator so why look towards a transit?
Threads: 12
1
Given 0 thank(s) in 0 post(s)
The transit ones need an oil feed too.
Threads: 128
21
Transit one is a common bolt on for the petrol Vitara with the 1.6 engine. But I didn't know which was good for the xud9
/Toseland
Threads: 91
12
Car Model/Spec: 306 D Turbo
I think that the 406 ones are a bit meatier....
Threads: 28
2
Car Model/Spec: Phase 4 Silver HDi Estate
Given 1 thank(s) in 1 post(s)
23-06-2014, 07:46 PM
(This post was last modified: 23-06-2014, 07:46 PM by Kwik.)
Hdi one is as said before 150amp. An xud9 one is 90amp so there is an upgrade. Best to look how it mounts first as there is several different types for hdi
