Bosch conversion - shopping list
Please forgive me if the answers are elsewhere in the forum, I tried searching but with little success...
Considering I cover 600 miles each week, it would appear that the option to run on svo/wvo would be well worth investigating as it would quickly pay for itself.
So my question is - what do I need to get in order to successfully swap from my current Lucas pump to a veg friendly Bosch one ? And is there anyone in the Wiltshire area who has done it before and could lend any guidance ? I've worked on classic Minis in the past but always open to assistance from a more experienced spanner-man.
You will need
Bosch pump complete with woodruff key and pulley
Fuel lines
Bosch injectors
A new cambelt kit and water pump is worth doing while it's in bits too
Team Doesn't own a 306
Injector washers/seals
leak off pipe
D-seal
As a bare minimum you can get away with just the pump, and pulley and woodruff key. You can re-use everything else, bend the lines and use the Lucas injectors. This is not idea just throwing it in there for anyone really scraping the barrel this month.
  Lucas to Bosch Conversion Phase 2 306 DTurbo FrostyHDI 2 3,147 01-12-2015, 02:43 PM
Last Post: Dave
  Bosch pump conversion problems Farmer-Glen 16 7,237 16-09-2014, 07:08 PM
Last Post: Farmer-Glen
  Bosch conversion nightmare sammyb303 11 5,997 04-09-2014, 08:04 PM
Last Post: Chris_90
