Manual boost controller help
Whats the easiest way to fit a manual boost controller to a hdi please? Pictures prefered Smile
Justin_306DTurbo
306 Ph1 Dturbo Sedan
306 Ph1 Dturbo Estate (VNT)
Partner Ph1 (XUD Swap)
306 HDI Stage 3 Estate (RIP)
Tbh, if you've got a KO3 then it's substantially easier to adjust the wastegate arm than fit an MBC
I couldnt tell you whats fitted lol, whats the easiest access to the actuator pipe? Was knealing on the slam panel but couldnt see nout
Justin_306DTurbo
Yeah to see it you'll have to get underneath it and look upwards, not a lot of room but once you see it you'll know it alright, on a KO3 you'll only need a long 10mm spanner to adjust the boost and I think it's just a thumb screw on a GT15 but not 100% sure
Still wanting to fit the manual boost controller though, im guessing thisnwould of been easier to fit when I did the fmic lol
Justin_306DTurbo
  Boost controller GFB G-FORCE II loli_04 6 5,068 18-03-2017, 11:03 AM
Last Post: loli_04
  electronic boost controller ??? Donkeybubles 5 3,619 16-07-2015, 03:41 PM
Last Post: JTaylor2005
  manual boost controller and egr blank plate fitting, please help dirtyboost89 6 4,363 02-03-2015, 11:50 AM
Last Post: dirtyboost89
