Gti6 Braking pressure compensator
Could someone shed some light on this please as not 100% sure, going to change my ph1 non abs drum rear axle (which doesn't have a compensator) to a ph2 gti6 rear axle which has brake pressure compensator to even the braking, would I need to buy all new hoses/pipes for compensator? if so where from? What are the pipes for it called? As been told it's fine to just leave abs off new axle on rear
 Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
You should be able to change beams workout disrupting your hydraulics. Check the gti6 forum beam change faq.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
The solid brake lines finish in a different place under the car.
When fitting my ph3 beam to my ph 2.5 the lines didn't meet and were short by about 4 inches. You could either make something up to suit, or swap lines over on the beams Smile
  Brake compensator differences Ben_w 8 7,267 03-03-2018, 01:44 PM
Last Post: Mighty306
  Brake compensator rocker8742 1 2,748 22-05-2016, 12:28 PM
Last Post: cully
  Rear brake compensator - 94' S16 lpr1981 2 2,484 09-08-2015, 11:40 AM
Last Post: lpr1981
