Rear brake compensator - 94' S16
Hi all,
I have just got to the stage of bleed the brakes through on my S16 project got half way through and realised the rear brake compensator is leaking like a sieve. I have looked through 'Service Box' and the part 4861 68 is marked No Further Production!!
I have taken a look similar threads on the forum but I cannot see anybody mentioning one leaking, load of people saying about them being seized which mine is aswell.
I will take a closer look at it tomorrow to make sure it's the compensator leaking and not a pipe.
Are these compensators repairable? e.g. seals
never heard of one leaking, though not impossible I guess as it is a piston so must have seals.
a gti unit will do the job, I guess they'll have a slightly different pressure rating as they ran bigger front pistons so will need a different front to rear balance.
Just hooked the pressure bleeding kit up to the S16 again and yep the compensator is pouring it's heart out. Time to find a replacement!
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,056 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 3,963 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 5,912 24-04-2018, 07:11 PM
Last Post: Ben
