Air mass meter chip?
Just seen this on ebay. What do we think there are like? Mae the car run like its a morning all the time or just a waste of time?
http://www.ebay.co.uk/itm/AIRFLOW-METER-...2ecf43ef6a
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Its just a resistor to fool the ECU.... It will give more power under certain conditions, but will ruin fuel components and make it smoke like a bitch... Your choice though lol.
It's a resistor exactly like the ones that go on the fuel pressure sensor, aka a chip. Just like any other chip it'll ruin your high-pressure system sharpish and if it's a "powerful" one it'll melt bits of engine/turbo too. I see the advert actually specifies it's not for diesels too, did you even read it..? Rofl
(03-03-2014, 09:43 PM)Poodle Wrote: It's a resistor exactly like the ones that go on the fuel pressure sensor, aka a chip. Just like any other chip it'll ruin your high-pressure system sharpish and if it's a "powerful" one it'll melt bits of engine/turbo too. I see the advert actually specifies it's not for diesels too, did you even read it..? Rofl
lol I missed that part too haha.
No didn't read it just thought of POWER
Ph3 perv cab heaven
Black ph1 XUD died
Don't you already have a S2 HDi anyway lol? How much more power do you think you can get with your current setup? Confused
Hahaha POOOWWEEERRRR!! If you want to go past stage 2 you need to look at better turbos before looking at more fuel, various people have made ~200bhp on stock injectors so we're good until then.
Ye got a S2 HDI 154bhp but bord of it now
Ph3 perv cab heaven
Black ph1 XUD died
Yeah, always the way - more is never enough lol.
That's the problem. 200bhp sounds nice but think the clutch can only hold up to 300 torque think it's 290 now
Ph3 perv cab heaven
Black ph1 XUD died
What clutch is in there?
What turbo you running 290 lb with?
(04-03-2014, 09:39 AM)karl1989 Wrote: Ye got a S2 HDI 154bhp but bord of it now
(04-03-2014, 12:11 PM)Poodle Wrote: Yeah, always the way - more is never enough lol.
Definitely know that feeling! Have to drive something shit and slow now and then so it feels fast again after lol. Big Grin
Here's the clutch. 154bhp 280lbs/ft on standard turbo
[Image: muge8eze.jpg]
[Image: equze3yh.jpg]
Ph3 perv cab heaven
Black ph1 XUD died
Seriously only 300lbft? I'm sure Brynllwlywwnlynnog was running about 350 on one of those before the engine popped a leg out of bed...
Sure Arron said it was capable off holding 300. Sure it's got something of a berlingo too
Ph3 perv cab heaven
Black ph1 XUD died
Ill try again, with what turbo are you making 290 lb
(04-03-2014, 07:20 PM)mcglynn Wrote: Ill try again, with what turbo are you making 290 lb
Not sure what's on it. Haven't looked
Ph3 perv cab heaven
Black ph1 XUD died
Unless its some sort of hybrid/bigger turbo it probably wont makd 290 lb lol
[Image: ahejeduj.jpg]
Ph3 perv cab heaven
Black ph1 XUD died
Seeems like a very strange figure for a standard turbo if im honest
Yeah it's a tad high for a standard turbo, probably down to the guys running the dyno.
I imagine Arron put the berlingo pressure plate on it, as there were rumours it might have a higher clamping force.
He did have a run before I'll try find figures
246lbs/ft
141bhp
Graph to follow... Was at 18.4 psi too. It's around 21psi now with a boost leak
Ph3 perv cab heaven
Black ph1 XUD died
Found some figures from Bryn's build - 245lbft. Hell knows where I got 350 from, wishful thinking probably lol. Even TB's monster 206 only made 330lbft at ~210bhp, so I think it's fairly obvious there's something up with that dyno, although I see the figure is creeping down. Wink
Anyway, bear in mind performance clutch manufacturers have to cover their arses to some extent, so chances are the clutch will happily hold 350+. My 130k valeo seems to be handling ~230lbft ok and i'm fairly sure they're not rated past 180. Drash on and see what happens, worry about it if/when it starts to slip tbh.
I read somewhere about these readings being from stationary, whereas a clutch in a car womt be subject to 0 - 350 lbft in a short time nevermind in an instant
Think the 154 graph was at the Yorkshire rr and they seem accurate but if it is 154 then I'm use to it and it's boring Sad
Ph3 perv cab heaven
Black ph1 XUD died
If you're bored of the power, then you're bored of the power, doesn't really matter what the power is. All that matters now is the size of the turbo you're going to strap on. Big Grin
Expect the reason why it 'feels' slow is the way the power/torque drops off after it peaks
Not sure what turbo I want yet
Ph3 perv cab heaven
Black ph1 XUD died
Photo HDi Tuning Chip wainwrightj 37 29,194 27-04-2018, 09:36 PM
  307 Dual Mass? ct-hdi 11 8,312 05-04-2014, 09:16 PM
Last Post: ct-hdi
  Tuning Wizard Remap Chip MY95 15 8,936 09-02-2014, 11:30 PM
Last Post: WiNgNuTz
