Knocking and stalling feeling pulling away..
Are these the symptoms of one of the mounts going? If so, which one is most likely?
I couldn't see any movement in the top mount, but when pulling away in 1st I can sometimes feel the engine shake, like it's trying to stall, even though it's not - if that makes sense!
I'm going to be working on the car soon so could get this sorted at the same time...
[Image: Sig500x130.png]
Knocking when pulling away hard would suggest engine mount, but I never got any stalling feeling when my mount went.
Definitely one of my mounts on its way out I reckon, this has recently got worse. The whole car judders when pulling away from a standstill.
Which one is it most likely to be? I can't get it to do it without being under load, if that gives any clues?
Pop the bonnet and give it a shake, if its that bad then you shoukd be able to tell.
The bottom mount would cause the most amount of movement, get under and check that one
Could be a cracked cup on the top that the mount screws into.
Bye Bye D-Turbo
  I'm having trouble pulling off. steve1001 13 11,264 29-01-2020, 11:28 AM
Last Post: pug306driver
  Knock when pulling away and under load titch 18 10,029 15-08-2013, 11:35 AM
