Phase 2 dturbo.with hdi brakes
Turns out estate has hdi brakes on.even listed under the reg on ECP. Is this a common thing on phase 2 estates
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
You sure they're HDi brakes? I haven't seen Lucas 266s on anything older than ph3. Might be Bosch 266s which are usually on 1.8s/XSis.
Yep measured them.
Blaze 1.6 Dead
They are also Lucas Calipers just had a look
Blaze 1.6 Dead
Ah fair enough then.
All estates had lucas 266mm fronts ...even the nads ...was estate brakes I used to upgrade my p1 ...saloons all got stuck with 247s
Ah that's interesting, never knew that.
  Upgrading to 283mm brakes on Dturbo Hobo Ash 15 8,266 01-07-2017, 11:34 AM
Last Post: Hobo Ash
  Smallest wheels to fit dturbo brakes ginge191 12 7,770 26-09-2016, 05:38 AM
Last Post: ginge191
  Estate Rear Beam On A Phase 1 Dturbo seanyleary 8 5,773 19-07-2014, 01:18 PM
Last Post: Toms306
