Locking wheel nut help
Hi guys not sure witch section this covers. Basically when I changed the clutch on the ph1 my partners brother tightend the front wheels with a air gun also the. Locking nuts Angry. Now I need to remove the wheels and the locking key is fecked its that tight. Used a friends locking but remover with the impact. Any other ideas. Here how it looks
[attachment=12839]
[attachment=12840]
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Smash a socket over it, biggest one that you can fit in the bolt hole (giggidy). Failing that, heat and a chisel to smash it round, go careful with the alloy though. Or you could go and buy a locking wheel nut remover tool set, but that seems a lot of money for one use.
Weld a nut to it Wink
[Image: av5ym8.jpg]
He has tryd a removal tool already. Would hitting the wheel from behind snap the head off ?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Tried a socket of the centre but to and no joy. Don't think I'll get a socket round the edge as it's tight to the wheel
Ph3 perv cab heaven
Black ph1 XUD died
Moved to the correct section and title corrected.
You would f*ck the wheel before the head snapped there high tensile bolts
[Image: av5ym8.jpg]
Looks like they may be left on for scrap
Ph3 perv cab heaven
Black ph1 XUD died
Iv removed wheels from scrap cars by hitting them from behind. It stripes the threads out of the hub. best thing to do is drill it out
drill it off
had to with one of mine Sad
(17-01-2014, 10:28 PM)cully Wrote: drill it off
How long did that take
Ph3 perv cab heaven
Black ph1 XUD died
Weld a nut on it lad and get a socket on it let the weld cool properly first though
Team Doesn't own a 306
reverse thread drill bit / bolt extractor?
(17-01-2014, 10:37 PM)tigerstyle Wrote: reverse thread drill bit / bolt extractor?
Never thought those to be of any use.
My vote is weld a nut onto it, preferably a big one, try and weld round the inside and the outside of it, depending on how much you value your wheels.
nearly a day cause i spent half of it in A&E after hitting my wrist twice with a hammer trying the socket method Blush
As said drill it or weld a nut onto it, some of those lock nuts are very hard you need a good drill bit or you'll not even mark it.
  Removing locking wheel nuts? Colactix 12 11,052 13-03-2021, 01:30 PM
Last Post: Colactix
  Locking wheel bolt key Ricky 6 4,230 16-10-2013, 08:54 PM
Last Post: bigcheez2k3
  Locking wheel nut mad306man 6 4,138 19-05-2013, 05:01 PM
Last Post: mad306man
