Dw10 fuel supply/filter.
Hi all, I need to create space in the engine bay of my 205. By removing the original filter and associated Gubbins I would gain plenty.
Can anyone see any issues in using an inline filter? As long as the inline filter has a micron rating of 5 it should be OK.
Only problem I can see is inside the fuel filter housing there is a pressure regulator. This regulates the supply pressure to the pump, by removing the housing the HP pump will be getting the full fury of the in tank pump.
I never managed to find any information on the in-housing regulator, but being a simple spring-loaded arrangement i suspect it's just there to stop the hp pump being run dry. I know a couple of people have run with an alternative filter in the past, apparently without problems, so can't see it being an issue.
How is your 205 coming along? Thought i'd check your thread since i haven't looked at it for ages, only to find it seems you haven't either. lol
Not updated much as I haven't been in there for a while. My original plan of charge cooling is more than likely being replaced with a FMIC set up which is why I want to move the filter etc.... Besides that the car runs nice and smooth. I just need new brakes, tyres and sort the inter cooling out ready for MOT.
I've been researching which is the biggest intercooler I can fit above the rad but there ain't much space-
[Image: IMG_20130712_232759_zps3210f25d.jpg]
Still not 100% which to choose.
Fairy snuff, married life not taking it's toll, i hope..? Wink
Ah, that makes sense. That really isn't much space is it... I reckon there's a few about that should fit nicely though, what are your options so far?
Jag x type diesel intercooler would fit there nicely.
I cant see an issue with relocating the filter either, as poodle says the regualtor isnt exactly a high tec bit of kit and a dont think a 1 bar change in input pressure is going to hurt the CR pump that runs at 1800 bar and has its own regulator
Lol the days of working all night in the batcave have unfortunately reduced, hence the lack of updates.
My options are up to now-
+Continue with the P38 oil cooler as the charge cooler pre rad, then get a custom thicker one made at a later date.
+Fit a 4x4 cosworth intercooler.
+Fit a landrover discovery 3 intercooler.
+Fit a BMW E61 intercooler.
Last option which would break the whole standard GRDT look..... Strap a BFO universal one up front.
(12-01-2014, 05:55 PM)Dum-Dum Wrote: Jag x type diesel intercooler would fit there nicely.
While trawling eBay for an x-type intercooler I might have found one which will fill the space perfectly :-)
The e39 one's are almost identical in overall dimensions and are about half the price on ebay. Wink
^^^ I did wonder that
Looks like it will be a good fit-
[Image: Screenshot_2014-01-13-08-54-48_zps5pripona.png]
  Fuel Filter pug306driver 8 6,838 25-01-2019, 09:50 AM
Last Post: pug306driver
  fuel filter housing changed jason68 6 5,203 08-01-2018, 02:14 PM
  DW10 vs DW12 vs DV6 Dreijers 43 35,136 03-12-2017, 11:54 AM
