Drivers side drive shaft, nuts
Just wondering if anyone knows the size of the nuts that go on the 2 L shaped bolts that hold the drivers side drive shaft bearing in the housing.
Looking on service box it normally tells you the size, had a quick look and it says
7X100-7-11 so does that mean 7mm so an m7 nut ?
Cheers Titch
Yeah, its a 11mm head.
Have fun - they can be a pig! Especially if they've been over-tightened or have started rusting.
[Image: Sig500x130.png]
Cheers, i have already done the shaft did it yesterday, just didn't have any new nuts so will replace them when i can get some new ones.
Titch
Rainbow Drive shaft gear box seal Welshy_Pete 9 5,471 12-03-2014, 07:38 PM
  Drivers side, drive shaft question titch 11 4,932 02-01-2014, 06:27 PM
Last Post: titch
  Drive shaft/Diff puglove 18 8,336 02-08-2013, 09:02 AM
Last Post: Connor
