Wheel bolts with nimrods
I know they will need spacers to fit but will these bolts be alright I'm not sure if I would need flat seated? http://bit.ly/1fx2Nre
Bye Bye D-Turbo
Yeah, you need flat seated. I used extended bolts with conical>flat adapters, like these: http://www.ebay.co.uk/itm/M12-FLAT-SEAT-...20d61d61cc
(03-01-2014, 11:06 PM)Curt Wrote: Yeah, you need flat seated. I used extended bolts with conical>flat adapters, like these: http://www.ebay.co.uk/itm/M12-FLAT-SEAT-...20d61d61cc
What size spacers did you use?
15mm on the back, nothing on the front.
So these would work with the bolts that come with the spacers in the advert I put up?
Bye Bye D-Turbo
I can't see why not, they both say 60 degree taper. That's not where I got them from by the way, just some I found from a quick search.
Thanks mate that's a big help Smile that price isn't too bad for the washers did you get them cheaper than that then?
Bye Bye D-Turbo
  Quick question about cyclone wheel bolts titch 11 6,387 06-05-2014, 09:58 AM
Last Post: cully
  Wheel Bolts 306 d turbo 1 2,392 01-05-2012, 03:32 PM
Last Post: 306 d turbo
  Wheel bolts Matt 6 3,599 08-03-2012, 08:58 PM
Last Post: Matt
