Threads: 102
18
Not much has really happened with this other than random little things like bulbs etc.
However, I have been running a stainless straight through centre-section with a scorpion backbox for a while and it sounds bloody great.
Once I've got an external mic I'll be making some gopro vids I think.
Threads: 102
18
Hit 60k yesterday.
Not to worry, I should be getting a daily sorted soon so that this can be more pampered.
Threads: 102
18
Still not a great deal happening, been driving it to work and back every day and racking up the miles, 60500ish now. Off to look at a new daily this weekend so hopefully this will become a driveway queen and only be used for weekend blasts.
Also bought parts for servicing it and recieved some shinies today, TD pro race 3s 15" in white. Crap garage pic:
Threads: 541
124
Threads: 58
White wheels make cars go faster
Threads: 26
Mmm, I do like white PR3s!
Threads: 61
11
Wheels look great,only problem with white wheels is it shows the arch gap more.
Threads: 120
35
Those wheels are horrific! you cannot be actually considering bolting them onto your lovely car?
You should sell those revolting wheels immediately without delay!
In fact pm me a price so i can help with the sale
Team Cyril
Threads: 102
18
11-12-2014, 08:12 PM
(This post was last modified: 11-12-2014, 08:14 PM by RetroPug.)
Yes! I've wanted a set of 15" pro race 3s in white for aaaaaages but they so rarely come up for sale, got these for a good price and they are 15" 7J and 4x 108PCD so perfect. Saw them for sale for a little while and kept telling myself I shouldn't then I MTFU and bought them.
Just need to get round to going and measuring the offset. Couldn't find it stamped anywhere on them.
Matt-rallye that'll be 1 million pounds posted.
On a serious note the tyres will probably be for sale, think one is punctured, all worn a lot on the very inside edge but the rest of the tyre has loads of tread. Maybe someone will want the other three to use for a cheap trackday or something.
Also I have a bare metal OMP strut brace that I haven't gotten around to doing with other than unwrapping.
Threads: 102
18
02-01-2015, 05:02 PM
(This post was last modified: 02-01-2015, 05:02 PM by RetroPug.)
https://www.youtube.com/watch?v=YsOVloLBnfE
Little blast to test the go pro. Quality sucks, need to mess with the editor to stop it compressing it so badly. Drove pretty slowly as the mount was new and I didn't want to lose a brand new go pro!
On the plus side it sounds great.
Car got an oil change, filter and new spark plugs today, plus swapped for spare coilpacks to hopefully solve hesitance from cold.
Threads: 26
My sister got me a go pro3 for my 40th. I thought it was some sort of joke or dig and it has only been used once.
But having seen this I should get a car mount.
Threads: 102
18
This is the first time I've used mine. I'll also be taking it skiing in about a week which should generate some amusing footage of people falling over!
I bought some sort of extremely cheap knock-off handlebar mount that I put on the tow hook.
It doesn't quite clamp securely though so might have to make a collar or bodge something else together.
I don't trust the suction mounts.
Be advised that you'll probably get windy sound outside the car with just the camera and no microphone out of the airflow.
If you get a genuine go pro mount, the suction cup could pull a dent out of a body panel. They are seriously good and i have no worries with sticking mine to the car anywhere!
Threads: 102
18
Fair enough.
Tow hook mounting seemed to be pretty cool. Really need to sort out the editing side to maintain footage quality and size though.
I bought the car with almost no history. In just over a year of ownership I have built up a bit of my own:
Threads: 61
11
03-01-2015, 12:06 PM
(This post was last modified: 03-01-2015, 12:07 PM by 7057sam.)
If it a 3 then they should be a external mic output which can then run a mic to anywhere on your car jammapic did a video with different mounting postions with it a certainly made a difference.
Threads: 102
18
(03-01-2015, 12:06 PM)7057sam Wrote: If it a 3 then they should be a external mic output which can then run a mic to anywhere on your car jammapic did a video with different mounting postions with it a certainly made a difference.
That's what I did. The microphone was on the airbox.
Threads: 102
18
Test fitted wheels today. Noticed a lot of play in the front left brake disc and alarmingly both the retaining screws were barely on, and as soon as I touched one the head just dropped off.
I'll be getting new screws for both sides just to be sure, although the right hand side doesn't have any play in it.
Anyway, the wheels look good, fit perfectly and sit very nicely spaced out by 20mm. I just need to get my tyres swapped over onto them and get four locking nuts and then they can stay fitted.
Threads: 61
11
Looks sweet,how does it side after fitting the wheels
I know after fitting my 1.2's I had to lower it abit more.
Threads: 102
18
If you mean sit I didn't put it back on the ground, put the cyclones back on.
Three tyres are either low or not legal and one is flat. The ones that aren't legal are worn just along the inside edge the rest have good tread so maybe someone will want them for track tyres.
Hurry up and get some tyres on them.
Also the disc screws aren't important, they're only really there to stop the disc spinning when putting the wheel back on. The disc is clamped between the wheel and hub by the wheel bolts.
Threads: 102
18
(04-01-2015, 03:58 PM)Toms306 Wrote: Hurry up and get some tyres on them.
As I thought but even with the wheel on there's unacceptable play in the disc.
How can there be unless the wheel is lose as well?
Threads: 465
114
Car Model/Spec: Vauxhall
(04-01-2015, 05:17 PM)Toms306 Wrote: How can there be unless the wheel is lose as well?
this!
the wheel clamps the disc to the hub with the wheel bolts
all the little torx bolts do is stops the disc turning when you try to line the wheel up with the bolt holes
Threads: 102
18
04-01-2015, 07:36 PM
(This post was last modified: 04-01-2015, 08:01 PM by RetroPug.)
I'll go and double check how tight they are then.
Edit: All good. I was sure I'd checked after tightening the wheel nuts and found play but I must have done it before fully tightening them.
Thanks.
Threads: 102
18
At 62 thousand miles (so I'Ve done 9k in it) this has finally been retired from the drudgery of plodding through average speed checks to work on salty roads and is now a weekend toy!
Threads: 102
18
Not much has been happening, mostly due to work and crap weather, but I've serviced it using genuine oil, filter, NGK plugs and swapped coil packs for a known good set which go rid of cold hesitation and made it run generally better everywhere.
Needs a blow sorting from the cat outlet pipe which is making it sound very loud and farty.
Other than that I've been gradually accumulating shinies:
I need to get tyres swapped onto the new wheels but I can't find anywhere near me that charges less than 50 quid sadly.
Threads: 61
11
Nice what springs are you going to run with them? ?
Threads: 102
18
I'm thinking eibachs with the rear beam lowered to suit but not sure at the moment. Need to source a set of rear dampers, and would like to stick a rebuilt beam on rather than just lower a worn one and have good dampers and springs but bad wheel geometry anyway due to a bad beam. Have an OMP upper brace to fit along with this but can't decide on colour.
Threads: 141
35
lovely things have happened since I last checked up on this thread love the pr3's they suit a ph1 perfectly
