17-12-2013, 11:05 PM
When I'm manouvering slowly like a 3 point turn for example I have heard a loud clunk or knock as I turn the wheel. Could this be a drop link or anti roll bar? Can't say I've noticed it over bumps when driving
clunk knocking sound
17-12-2013, 11:10 PM
Where from? The front? Drivers or passengers side? Middle?
Does it do it whilst turning during regular driving? Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
17-12-2013, 11:13 PM
Sorry from the front. Possibly front right. Not noticed it during driving
Sounds like coil spring broken or not seated right
Or top mount/bearing perhaps Wishes for more power...
17-12-2013, 11:15 PM
How can I check that? Is it a big job if it's that?
17-12-2013, 11:25 PM
(17-12-2013, 11:13 PM)Piggy Wrote: Sounds like coil spring broken or not seated right Or the p-bush Or the drop link Or the ball joint Or the TRE Or the ARB Bush It could be ann manner of things whodafunk. You really need to get under there with a pry bar and start moving things about to recreate the noise if possible. The best way of eliminating/diagnosing Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
17-12-2013, 11:28 PM
Mine did this, turned out to be a knackered P bush of all things =\
17-12-2013, 11:37 PM
p bush is a good call...
Be unlikely to be drop links/ARB unless turning on a uneven surface. TRE is not normally heard to make noise, same goes for ball joint. But get a torch and pry bar as said, and give it a good inspection. Try with it on ground and jacked up as it loads different parts Wishes for more power...
17-12-2013, 11:45 PM
(17-12-2013, 11:37 PM)Piggy Wrote: p bush is a good call... Dude, what are you on tonight?! Of course they are going to make noise if they're f*cked! My TRE's are currently knocking more than Peter North's bedside table... Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
18-12-2013, 12:27 AM
I had a knock over bumps, was bottom ball joint. It happens.
Like had been said above, you might get underneath and your p Bush is flapping in the wind !
18-12-2013, 12:36 AM
But its a loud clunk only when turning stationary...not when driving
Yeah it's only when turning at slow speeds, like a 3 point turn. It's also pulling to the right aswell.
Also how should the coils sit? The base of each front coil is uneven. Hard to describe but it's curved where the spring sits on it?? I've got it booked in my father-in-laws garage on Saturday to have a good look on the ramp. EDIT: Just reading this thread and my symptoms seem very similar... Maybe the coils need greasing http://306oc.co.uk/forum/thread-15519.html
21-12-2013, 03:46 PM
Just had it up on the ramp and it's the drivers side spring. It's gone upwards and is resting on the turret. Anyone know a good place to buy coil springs from?
21-12-2013, 03:56 PM
Dont mean to be big headed but....
Anyway. Is it a standard coil spring or uprated one?? Its best practice to do them in pairs Wishes for more power...
21-12-2013, 05:30 PM
I know mate, you called it
It's just a standard one. Found this on eBay... http://item.mobileweb.ebay.co.uk/viewite...2432918074
21-12-2013, 05:35 PM
That would do it so long as yours is a hdi
Worth trying your local factors...sometimes cheaper than you think. Also worth considering some second hand upratrd springs which often can be had for £30-40 for a pair and it is best to replace them in pairs Wishes for more power...
21-12-2013, 05:55 PM
I'm gonna tackle the job myself so if I have any patience left I will do the other side.
They're 35 quid for a pair on ebay with free postage. Will try local outlets on Monday though as my father in law gets trade discount.
21-12-2013, 06:17 PM
(21-12-2013, 05:55 PM)Whodafunk Wrote: I'm gonna tackle the job myself so if I have any patience left I will do the other side. ALWAYS do suspension work in pairs! If your replacing one spring, make sure you do the other with the same brand.
21-12-2013, 06:27 PM
a large clunk is normaly the money falling out your wallet
but as said allready it could be any of the moving joints on the front best get your head in there and have a look
21-12-2013, 06:32 PM
Already diagnosed it Cully... But thanks
25-12-2013, 02:28 AM
(21-12-2013, 06:32 PM)Whodafunk Wrote: Already diagnosed it Cully... But thanks What was it mate? As I'm getting this from both sides but I've got brand new shock absorbers(motor factors brand) , top mounts, tre's, drop links on both sides and a brand new driveshaft, wishbone on the n/s / passenger side So not sure 100% on where it's coming from :/
25-12-2013, 08:31 AM
(21-12-2013, 03:46 PM)Whodafunk Wrote: Just had it up on the ramp and it's the drivers side spring. It's gone upwards and is resting on the turret. Anyone know a good place to buy coil springs from? It was this Dazza... And Cully Wishes for more power...
25-12-2013, 06:46 PM
(25-12-2013, 08:31 AM)Piggy Wrote:(21-12-2013, 03:46 PM)Whodafunk Wrote: Just had it up on the ramp and it's the drivers side spring. It's gone upwards and is resting on the turret. Anyone know a good place to buy coil springs from? Cheers piggy You in the festive mood today then? lol
The broken coil....
The new coil... I replaced both sides, aswell as two new drop links. It's like driving a new car now and no pulling to the right Springs were Monroe (OE quality) from eBay. £19.95 a pair http://www.ebay.co.uk/itm/360643980456?s...1438.l2649
06-01-2014, 06:13 PM
How the hell could you not realise it was like that?! Lol
07-01-2014, 11:49 AM
I did realise, hence why I got it on a ramp and replaced them. To be fair it didn't make a noise most of the time, just occasionally on full lock. It was only slightly lower at that side as the coil was broke at the top.
Anyway it's all done now |
Knocking sound over bumps | MisterGTR | 31 | 10,661 |
16-09-2016, 09:20 PM Last Post: insomaniac45 |
Knocking sound | kentiiboii | 11 | 4,148 |
23-10-2014, 09:49 PM Last Post: kentiiboii |
clunk when turning | rd070707 | 8 | 2,611 |
15-07-2013, 05:46 PM Last Post: RePT |
