Car won't switch off unless I press the brake pedal
Basically I turn ignition off and the car still runs but if I press the brake pedal it stops running and switches off BUT if I take my foot off the brake pedal all the electrics turn back on Undecided very irritating as I don't want it to be dead for tomoz morning anyone shed some light ? X x x
Anyone :-( kinda stuck here
Do your brake lights work correctly?
get under there and have a look...brake pedal must be moving/touchin sumit
Thats a new one, very odd but typical of french electrics
[Image: av5ym8.jpg]
Unplug the brake light switch. Must be shorting on something!
It's well weird car turned off ok just a min ago but the electrics keep turning on :-( again if I press the brake pedal it shuts the electric off Undecided I'm stumped
Disconnect battery if all else fails
That is a new one! Check that nothing has fused together in the main fuse locations. Also like has already been stated - look at the brake switch
Black mask Service
Fuses all ok the only way I've found so far to shut the whole car off electrics aswell is to take the shunt fuse out Undecided
I would check the loom that runs along under the rad bud!! These have been known to cause a car to carry on running!! Ɑnd fires aswell!!
The brake pedal thing ιs very strange
[Image: SDC10442-1.jpg]
It's stopped doing it today Undecided but it also dry when it was doing it it was peeing it down just wondering if water is getting somehwere and looked at the loom pal it's abit tatty on the plastic surround from bottoming out but the actual loom seems to be ok although now my central locking doesn't work maybe that's involved in this whitch craft ??
check the engine loom plugs on the chassis leg
and the plug block under the wiper motor through the bulkhead isnt submerged in water due to a blocked drain hole
Awesome ill have a look at those on Sunday as report back :-)
use a brick? lol
Really stumped on this one, sorry for a useless post.
Car seems to have fixed itself Undecided all working fine so I'm blaming whitchcraft and possibly rain getting into electrics somehwere
What craft? Tongue trolololol
Seriously though, it's a really odd problem.
Yeah tis a weird one Undecided will have to look into it abit more i think
So I got no ideas on this all wiring is ok guttering is all clear not water getting into any electrics all fuses and earths ok Undecided it's a mystery but isn't doing it any more. Undecided
Pretend it never happened Big Grin
Ok it has rained and gain it has happened :-( so am convinced its water getting in somewhere is there anywhere else I should be looking ??
HI
Probably a relay shortened, i had a problem like that:
my ignition was on even without the key in the ignition lol.
was 2 cables switched in on orange relay
If water is getting in through your aerial base or possibly sunroof if you have one, it runs along the headliner and down the a-pillar, and can get into the relays underneath the steering cowling. Remove your interior light assembly stuff and check if there is water in there and consider silicone-sealing this up to stop the water getting to your relays.
62k Diablo Phase 1 Gti-6:
Project Thread
  Brake light switch parts exploded view pug306driver 11 10,227 13-12-2021, 06:11 PM
Last Post: Mighty306
  Brake light switch pug306driver 10 8,685 14-10-2021, 01:18 PM
Last Post: pug306driver
Rainbow Brake light switch FIXED Welshy_Pete 13 8,608 20-03-2016, 02:17 AM
Last Post: Matt
