Drive Belt Length
Drive Belt Length
Could any of the resisdant HDI gurus tell me what length aux belt is required for a V plate 306 HDI. Its a non air con model...but has PAS with the pas pump up top...
Dont have a belt to measure to get rough idea...and internet seems full of different options...slightly un useral not to have AC i guess...
Also can anyone confirm, the spring loaded tensioner, is that the same across ALL 306 hdi's? Or does that differ also?
Cheers in advance.
[Image: sigi-2.png]
doesnt it have the spring/damper tensioner AND a manual adjusted aswell?
6pk1173 is what you use when you've removed the AC from a HDi
Hm pretty sure its longer than that, ive just mocked up a bit of string to get rough idea, and seems around 1500mm but obviously thats very rough..
[Image: sigi-2.png]
This is a 6pk 1173 fitted to a HDi
Hm, the setup I have is different to that...this is a model from the factory without AC...it has a small roller idler at the bottom and a sprung / dampened tesioner like that at the top...
[Image: sigi-2.png]
i think when people remove the ac they dont convert it to full Non ac with belt 1173
but the right belt is 1470 as it supose to double back around a second manual tensioner
6pk1470 is the non-ac belt iirc, so 1470mm.
Ah Cully got there first lol.
Which makes sence with my rough measure of 1500.
THanks guys!
[Image: sigi-2.png]
ThumbsUp
SO is T / G tensioners the same across all of them?
[Image: sigi-2.png]
Oh yeah sorry, forgot that bit lol. As far as i've seen the top spring-loaded tensioner looks identical across the various models, the other one/two vary. Haven't exactly seen loads of non-ac models in scrap yards though, so could be different on some i guess.
Ive already replaced the little idler at the bottom, id say they just added that to stop belt vibration, im going to run a guess and hope the ecentic tensioner is the same, cant see any reason why they would change it so ill order up and see...
[Image: sigi-2.png]
you could of course just bang the vin into servicebox to get the correct number, then cross reference :p
which tells me that it is indeed 5751 55 used on ac and non ac DW10 306's.
5750 XT is the belt part number, 6pk 1468
  de-aircon belt length rd070707 4 1,251 12-06-2015, 05:25 PM
Last Post: rd070707
  aux drive belt autoadjuster pug306driver 5 988 01-12-2014, 12:10 PM
Last Post: Poodle
  aux drive belt pug306driver 2 736 31-05-2014, 08:13 PM
Last Post: Jtrigga
