306 D turbo Clutch options
alright guys!!
i brought a d turbo 2 weeks ago its a ph2 one ! the clutch is nearly on its way out , just wondering what clutch options i can go down,
me and a friend are going to tune the car and make it into a sleeper hopefully its going to run around 180bhp by the time we are done
soo yeah what clutches would you recommend??
Cg motorsport 4 paddle unsprung clutch plate and a valeo. Pressure plate is what a few of my mates are using
[Image: av5ym8.jpg]
ahh cool ! do you know how much they are?
Just a friction plate alone is like 150ish I think :/
[Image: av5ym8.jpg]
My one cost £220 I think. To be fair though you can get away with a decent stock clutch like a Valeo.
Stage 2 XUD Sedan
hmmm that's not bad to be honest , hopefully me and my friend can make a really nice sleeper out of mine!
wouldn't the valeo one slip ive heard good and bad things about them running a bit more bhp??
Im a running a standard genuine valeo dt clutch.
2.1, 12v with a gt2056s....masses of torque and its done 3000miles of fine driving so far
Standard valeo for the price..
Stock clutch for now.
Spend your time and money reaching your figure first Smile
can upgrade just friction plate with CG for around £100. keeping the gen valeo pressure plate
(19-11-2013, 10:20 PM)Piggy Wrote: can upgrade just friction plate with CG for around £100. keeping the gen valeo pressure plate
Can you buy stock pressure plates on their own though?
Stage 2 XUD Sedan
As jimbo said CG paddle unsprung friction plate and vaelo pressure plate. That's what im running. I got lucky and got an old stock motaquip clutch (which is valeo) off ebay for £30 and used the pressure plate from that and I got the friction plate from CG which the guy did me a deal on 2 for £250 the pair, I think there usually £150 ish each for the friction plate he said.
They are pretty good at CG for discounting I would do a group buy but I've still got my old one sat in the garage waiting to go on the sedan.
Stage 2 XUD Sedan
I was pretty impressed with them. Only took a couple of days to come which wasn't to bad as im pretty sure they make to order
stock valeo clutch will hold up to 300lbft
Ruan - DT with GT2052V, TMIC, 11mm, Water Injection - 175.3hp 313lb.ft torque
Depends on what turbo you are running/going to run.
soo basically what your saying guys go with the stock valeo for the time being and when we have more bhp and if i have any problems from there consider a CG motorsports one ??
Yeah that sounds a good plan. I only changed mine cuz it was slipping even though I don't have a massive amount of torque. When I took the standard clutch off there didn't seem to be any thing wrong with it but it was defo slipping and since I have fitted the paddle clutch I haven't had any clutch slip problems
Personally I'd go genuine VALEO as you've mentioned and then move onto something beefier if that eventually wears out.
What do you guys rate LUK clutches like?
From what I remember LUK is rated more then Valeo for HDi's not sure about XUD's.
Probably CG>LUK>VALEO.
Im using a borg and beck with a td04, only really use the car at the weekends so its done about 8-10k of abuse and not slipped once
(20-11-2013, 03:37 PM)Daniel306 Wrote: Im using a borg and beck with a td04, only really use the car at the weekends so its done about 8-10k of abuse and not slipped once
Same here, using a Borg and Beck this last 40k miles, last 8k of which are on a K14-2. No problems atall!
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
hmm might go for valeo clutch then and see what happens from there !
Sweet LUK are over a tenner cheaper 56 quid for a 3 piece clutch
(20-11-2013, 08:17 PM)sherman306 Wrote: Sweet LUK are over a tenner cheaper 56 quid for a 3 piece clutch
To be honest I would stick a valeo in for the little extra as that's what everyone recommends for XUDs and its tried and tested. I haven't really heard anything on LUK clutches in XUDs
I thought LUK are on par with Valeo? is it not normal to get a valeo in a LUK box?
(20-11-2013, 09:51 PM)Daniel306 Wrote: I thought LUK are on par with Valeo? is it not normal to get a valeo in a LUK box?
They could very well be but I don't hear people going on about LUK like they do with valeo
LUK are ment to be complete oe spec and there warranty system is pretty decent
As long it's LUK/Valeo/CG I wouldn't worry.
It's the cheapo unknown eBay special brands you need to worry about.
(21-11-2013, 09:44 AM)silverzx Wrote: As long it's LUK/Valeo/CG I wouldn't worry.
^^ What he said
  XUD build turbo options Adam CD P1 16 19,034 26-12-2019, 07:03 AM
Last Post: monika16
  Tell me how to spend some money pls.. turbo options? 089 8 7,964 22-10-2018, 10:22 AM
Last Post: Dave
  clutch options? ash23 5 3,597 19-05-2015, 12:26 PM
Last Post: ash23
