Water getting into passenger footwell :-(
[Image: ve4uvujy.jpg][Image: uru9ydav.jpg].
Basically the wet patch on that cover is here it is leaking I cannot see where from and it's dry up there :-( but passenger footwell is considerably wet that little black pipe in the second picture is broken !!! What is it and is this maybe where it's leaking ?? Cheers
door seal . . . .poke some holes through the bottom of it . . .
Would the door seal leak into the dash Undecided seems abit high ?
The little black pipe is the drain for water that gets sucked in to the fan.
I would say the water might be coming from the damaged door weather curtain. Have you changed the speakers in the car?
Yeah I have aaaaages ago and been fine sense but that little black pipe has snapped at the join in the top so I would assume its coming from there ?? And how does water get into the fans does it run Down the scuttle
Panel ??
Door seal, heater matrix or sunroof.
It'll be one of those.
Or a large rust hole underneath.
That little pipe is snapped on pretty much every 306 I think...been a while since I've seen one still attached lol.
There should be a foam thing over the top of the cabin air duct under the scuttle to deflect the water from that area anyway though, unless the drain hole under the scuttle is full of leaves anyway...might be worth a check.
How would I tell if heater matrix is on way out ?? Heats up fine still boiling hot ? And will have a look under scuttle for leaves weirdly it was ok today and I was pretty much a boat last night Undecided no water in footwell Undecided
Matrix if the panel under the glove box is wet Sad
But it was directly under that broken drain of pipe so I've assumed it's that just checked scuttle no blockages to speak of and had heaters on and no leaks :-s
Would maybe just continuous heavy rain like heavy heavy rain maybe just not drain away fast enough and make its way in through that pipe ??
  Another wet passenger footwell Stevers 2 4,036 10-02-2021, 03:40 PM
Last Post: Stevers
  Wet Passenger Footwell, no coolant loss.... BikeJake68 2 4,446 12-05-2018, 10:34 AM
Last Post: Toms306
  Electrical burning smell and smoke in passenger footwell DeeTurbo 11 5,704 20-04-2016, 09:44 PM
Last Post: DeeTurbo
