Clutch cable help
Does anyone know how to get more slack from the clutch cable? Put newish clutch in 306 not got enough slack to get the cable in. :/
Pull harder?
Man up?
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
(08-10-2013, 09:14 PM)Tom Wrote: Does anyone know how to get more slack from the clutch cable? Put newish clutch in 306 not got enough slack to get the cable in. :/
Lever the arm back then connect the cable.
I have levered the clutch arm round and hooked it on but no surely its constantly resting on the release bearing and will f*ck it up?
new cable? If not, the adjuster needs resetting. Hook it in place then repeatedly stamp on the clutch pedal hard and you will find the biting point moves as the adjuster moves.
I stamped on it a few times but its still tight as feck. Im getting rid of it so i really dont want to be shelling out for parts.
  New clutch cable needed jcsh 3 4,714 11-02-2021, 05:01 PM
Last Post: ekjdm14
  Citroen ZX 1.9 TD Clutch Cable drew 0 2,711 17-05-2019, 12:58 PM
Last Post: drew
  clutch cable routing carlukepeugeot 4 5,511 29-10-2016, 08:24 PM
Last Post: carlukepeugeot
