Weird starting problem :s
A couple of weeks ago the car wouldn't start due to a faulty stop solenoid on the pump. I changed the solenoid and since then I've had a very intermittent starting problem.
90% of the time it will start first time, but the other times I have to put a jump lead from battery straight to solenoid, then it will start fine. As soon as its started I can remove the jump lead and it continues to run.
Seems really strange to me how its so irregular
[Image: 20120704_212316.jpg]
So without the lead it will just keep turning over on the starter or does it just click?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Without using the lead it just cranks and cranks. Pretty sure the solenoid is being opened by the ignition only 90% of the time. Once opened with the leads and its started I can take the lead off straight away and the solenoid remains held open
Try running a different ignition live.
I had a problem very similar to this wired it up to reverse sensor wires been fine ever since
Team Doesn't own a 306
(07-10-2013, 09:43 PM)Danny2009 Wrote: I had a problem very similar to this wired it up to reverse sensor wires been fine ever since
Exactly what I did when I had this problem
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
I'm going to do this later, does anyone know which wire will be the ignition live one? I have no multimeter and don't really want to have to cut more than one..
Also will I need to raise the value of the fuse as the wiring is going to be used for something which I assume will pull more current?
I would of thought the stop solenoid doesnt pull a serious amount of current like that. Cant help with the revers sensor though.
No I wouldn't think it uses much, I just thought it would use quite a bit more than a sensor..
The solenoid uses about half - 1 amp nothing much at all
  Starting problem.... Uberderv 4 3,698 09-06-2014, 08:10 PM
Last Post: toseland
  Odd starting problem. Danterzza 7 4,772 26-03-2014, 09:19 AM
Last Post: nominous
  XUD Starting Problem (Peugeot 306 1.9 DT) Gaz85 13 9,783 05-01-2014, 12:33 AM
Last Post: Gaz85
