02-10-2013, 12:13 PM
Oh well, for the amount of money saved we can't really complain..!
Bosch set up - advice required for storage
02-10-2013, 01:18 PM
02-10-2013, 08:28 PM
Right guys I am sold on this conversion but only from a financial aspect, a small out lay means cheaper running costs as all my driving is around town so need to be more efficient
I just need to save the dollar, which is easier said than done the smokey old bus that sounds like a tractor...
03-10-2013, 08:55 AM
(02-10-2013, 08:28 PM)devils_fuel Wrote: Right guys I am sold on this conversion but only from a financial aspect, a small out lay means cheaper running costs as all my driving is around town so need to be more efficient Right.. So you bought that 11mm then yeah?
03-10-2013, 08:47 PM
(This post was last modified: 03-10-2013, 08:47 PM by devils_fuel.)
(03-10-2013, 08:55 AM)silverzx Wrote: Right.. So you bought that 11mm then yeah? Nah... But I have been offered a complete Bosch conversion kit..the only problem I understand is the pump has not been stored in derv but the pulley and woodruff key are there... the smokey old bus that sounds like a tractor...
03-10-2013, 08:49 PM
(03-10-2013, 08:47 PM)devils_fuel Wrote:(03-10-2013, 08:55 AM)silverzx Wrote: Right.. So you bought that 11mm then yeah? Might be worth the risk if its cheap enough...
03-10-2013, 08:51 PM
(03-10-2013, 08:49 PM)THE_Liam Wrote: Might be worth the risk if its cheap enough... I don't think it's been stored dry for long, guess that's still bad then?...know nothing about pumps the smokey old bus that sounds like a tractor...
03-10-2013, 09:08 PM
(03-10-2013, 08:51 PM)devils_fuel Wrote:(03-10-2013, 08:49 PM)THE_Liam Wrote: Might be worth the risk if its cheap enough... Can go rusty inside if not been stored with Fuel in, I wouldn't risk it in your situation best to buy one that is known good you don't wanna be paying out twice if your on a tight budget
03-10-2013, 10:31 PM
(03-10-2013, 09:08 PM)Chris_90 Wrote:(03-10-2013, 08:51 PM)devils_fuel Wrote:(03-10-2013, 08:49 PM)THE_Liam Wrote: Might be worth the risk if its cheap enough... Did kinda think this mate, offered the full set up inc woodruff key etc for around 85... the smokey old bus that sounds like a tractor...
04-10-2013, 08:02 PM
(04-10-2013, 11:50 AM)silverzx Wrote: Crack on. But what if the pump is fubarred, I won't have any dollar to replace it the smokey old bus that sounds like a tractor...
04-10-2013, 08:13 PM
(This post was last modified: 04-10-2013, 08:13 PM by devils_fuel.)
05-10-2013, 09:30 AM
So sort him out, sell it on the basis if its broken he gets £40 refund or something.
05-10-2013, 01:25 PM
How longs it been stood? I bet it'll be completely fine tbh, ive had dry pumps that are years old fire up after some union slack/fuel flushing. Its when you dont flush them first and it pushes everything through the injectors that its baaadd... run it on the lucas ones for the first 1000 miles if your unsure, cos then you dont knakker the bosch ones.
05-10-2013, 01:35 PM
(05-10-2013, 01:25 PM)Dave Wrote: How longs it been stood? I bet it'll be completely fine tbh, ive had dry pumps that are years old fire up after some union slack/fuel flushing. Its when you dont flush them first and it pushes everything through the injectors that its baaadd... run it on the lucas ones for the first 1000 miles if your unsure, cos then you dont knakker the bosch ones. Sounds like sound advice! Get on it.
05-10-2013, 05:36 PM
(05-10-2013, 01:25 PM)Dave Wrote: How longs it been stood? I bet it'll be completely fine tbh, ive had dry pumps that are years old fire up after some union slack/fuel flushing. Its when you dont flush them first and it pushes everything through the injectors that its baaadd... run it on the lucas ones for the first 1000 miles if your unsure, cos then you dont knakker the bosch ones. Not sure Dave, Tom can furnish with that info. That is sound advice about the injectors though, cheers fella Just need to do the deal now. Anyone local to Bristol that can do the conversion as Mr Lobb is busy and cannot fit it -he is local to Tom so was hoping to hit 2 birds with one stone but hey.. the smokey old bus that sounds like a tractor...
06-10-2013, 01:56 PM
I was told to unscrew the max fuel screw. if its rusty the pumped f*cked
97' 106 XT 1.6 - Mayerling Green - Swapped 95' 306 P1 DT - Onyx - Scrapped 97' 306 P2 DT - Silver - Scrapped 97' 306 P2 DT - Onyx - SORN awaiting scrap
06-10-2013, 03:41 PM
(This post was last modified: 06-10-2013, 03:42 PM by devils_fuel.)
(06-10-2013, 01:29 PM)Dave Wrote: I can do this if you ship your car to Asia I'll get cracking then Dave, what's your address... (06-10-2013, 01:56 PM)adamm306 Wrote: I was told to unscrew the max fuel screw. if its rusty the pumped f*cked Thanks, will have a look when I get it. A Bosch pump is fully serviceable isn't it, or just scrap?? the smokey old bus that sounds like a tractor...
06-10-2013, 10:49 PM
I'm in the Midlands... The opposite way to those cornish lot, however I'd be willing to help for a crate of Rattler....
06-10-2013, 11:43 PM
(06-10-2013, 10:49 PM)DarkInferno Wrote: I'm in the Midlands... The opposite way to those cornish lot, however I'd be willing to help for a crate of Rattler.... I'm kinda looking for a mechanic to do cambelt/water pump as well as the conversion the smokey old bus that sounds like a tractor...
07-10-2013, 04:38 PM
(This post was last modified: 07-10-2013, 05:01 PM by devils_fuel.)
Right I have bought the kit (to be delivered) but it will not be fitted straight away, so what is the best way to store the pump/kit as it could be stored dry in the house or in the shed
07-10-2013, 05:56 PM
(07-10-2013, 04:38 PM)devils_fuel Wrote: Right I have bought the kit (to be delivered) but it will not be fitted straight away, so what is the best way to store the pump/kit as it could be stored dry in the house or in the shed Fill it full of derv would be best bet other than that think it should be ok just make sure when you fill it full of derv it don't spill it all over in shed |
Bosch ve removal advice please . . . | Mattcheese31 | 6 | 3,015 |
23-01-2017, 02:26 PM Last Post: Mattcheese31 |
Bosch guide/advice | Nathan1305 | 4 | 1,596 |
18-01-2015, 11:09 PM Last Post: Nathan1305 |
Storage question? | 306pc | 0 | 681 |
30-04-2014, 12:02 PM Last Post: 306pc |
