11-09-2013, 03:41 PM
Have many people change these? I'm sure I've seen a few threads where they've been changed but not much info on how to go about it.
Roof Lining And Carpets
11-09-2013, 03:45 PM
Ive recovered a few headlinings, heat resistant glue, smooth it on and trim to fit. Sorted.
11-09-2013, 03:48 PM
I was thinking more on changing the colours of both can you get them made to fit?
11-09-2013, 04:21 PM
A lot of people now seem to have swapped carpets for the blue ones which came out of phase 1 xsi's like I have
11-09-2013, 05:08 PM
The roof lining you need to:
-Remove all the grab handles -Remove all the lights in the lining -Remove the boot seal trim -Remove the sun visors -Remove the door seal trims -Remove the A,B,C pillar trims Then its a case of working it away from the roof skin. It is spray adhesive'd to the roof. The carpet: -Remove the door seals -Remove the seats and all associated brackets -Remove the petrol flap release -Remove the two 10mm bolts on either side of the dash (one goes through the bonnet release for an idea of location). There may be one or two I have missed. I know the front carpet can be tricky with the dash in place. Its easier to do both in one job as the roof lining will be easier to manoeuvre with no seats, and you will have the door seals off already etc. ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
11-09-2013, 05:14 PM
I have a two spare roof lining, one already covered in material if you want to practice.
But they are pretty easy to remove. As posted above. I have done black, blue and brown before.
11-09-2013, 05:42 PM
If you've got ac the exhaust for it goes through the carpet in the passenger footwell but I've just put a small cut to let that slot in
11-09-2013, 06:39 PM
That helps with the removal / fitting thanks for that Grant. Whats the best way to modify it?
11-09-2013, 06:44 PM
'Modifying' the carpet will be hard. TBH you'd probably do best to bleach it and then dye it using proper fabric dye or similar.
The roof lining can be easily trimmed using fabric and spray adhesive as stated above. ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI |
| Fabric for roof lining | andyyy | 4 | 4,128 |
21-08-2015, 12:02 AM Last Post: Adam-m-h |
| Roof lining | Adam-m-h | 53 | 36,120 |
18-08-2015, 03:17 PM Last Post: Adam-m-h |
| Interior light surround thing, on the roof lining? | Dean | 9 | 6,828 |
02-10-2013, 10:36 PM Last Post: Dean |
