spot lamps front trouble
im having a few problems locating a fault on my front spots, they just wont work. could you point me in the direction of fuse position and possible reasons
(08-09-2013, 05:49 PM)thehytheman Wrote: im having a few problems locating a fault on my front spots, they just wont work. could you point me in the direction of fuse position and possible reasons
If you've got a 306 and you mean the front fogs then the fuse is in position 18 and is a 10amp fuse if the fuse is ok then try the relay which is the green relay on the bottom row nearest the drivers door had that trouble with mine but that was because I put the relay in the wrong place. hope this is helpful
thanks I will take a look.
  Bumper mounted spot lights Adam CD P1 12 6,877 21-01-2016, 02:43 PM
Last Post: tigerstyle
  (Help) Seat-heater trouble shooting distinctionx 2 2,980 24-11-2015, 04:26 PM
Last Post: distinctionx
  Spot Lights pugtk 4 3,304 21-01-2015, 09:09 AM
Last Post: Pug0BZ3011
