(Help) Seat-heater trouble shooting
So the light comes on when the button is pressed down, but there's no heat coming?
I figure the heaters might be dead, but how can I make sure they are and that there's not another problem?
Pug 306 Ph2 1997
We never had seat heating as an option on the 306 in the UK so not sure we can be much help!
I would assume they use a relay to switch a 12v feed? If so test for 12 volt at the plug when you push the button. If no voltage, check the fuse and relay (if applicable). If there is power there but still not working, the heater is most likely broken. You could try outing a direct 12v to it just to make sure.
(24-11-2015, 10:18 AM)Toms306 Wrote: We never had seat heating as an option on the 306 in the UK so not sure we can be much help!
Thanks, my pug is my very first car and has owned her for just 5 months.
Never been a cars-enthusiast before, so I'm trying to learn anything I can.
  spot lamps front trouble thehytheman 2 2,939 08-09-2013, 06:06 PM
Last Post: thehytheman
