HDI fitting a manaual boost controller
As ive got my fmic and stage 2 tune on with my exhaust
Ive got a manaul boost controller and some vac pipe, not a hope in hell of getting at it from the top and underneath ive taken the inner arch out which exposes the bottom crank pulley.
Basically there is little or no room to work with ive searched across the forum but no look in a guide or whats not,
Do i need to take that turbo inlet pipe off ? to have a better stab at it or whats the best way to tackle it
Any inputs be much appreciated Smile
There is a guide but aparently its not the easiest way of doing it and the guide is really confusing to read with all the comments too. Never done it so i cant help im afraid.
Have a look at the guide for pics and more info. Basically you need to install the boost controller so it interrupts the wastegate actuator feed, top of the T goes on the inlet side, the l of the T goes to the actuator. Best access is through the wheel arch or from underneath, both are a total bitch tbh, so its down to personal choice. Hth. Smile
I cant find it could you link me found one for the xud but not the dw10 im almost tempted to have that pancaked pipe chopped and replace it with silicone pipe
Weather its a good idea or not I dont know
Boost controllers of that type are universal, they're all the same, or near as makes no difference.
  Boost controller GFB G-FORCE II loli_04 6 5,063 18-03-2017, 11:03 AM
Last Post: loli_04
  Recommendations for boost gauge and fitting kit 306rhys 6 4,518 30-07-2015, 07:56 AM
  electronic boost controller ??? Donkeybubles 5 3,617 16-07-2015, 03:41 PM
Last Post: JTaylor2005
