Water leak inside the car
When wash the car there a water leak inside the car. Were the interior front light is all the water comes from there. Then goes on the floor drivers and passanger side.
I think it might be coming from the aerial?
Take the aerial off fill with sealent, job done
Yes it is, take the aerial out, squirt some silicon around the hole and refit the aerial
Thanks will let you know once I have done it.
I still have mine, and I dont have an aerial, no more. Been removed and filled in. No idea where mine is coming from, maybe a leak from the sun roof into the area where the aerial use to be.
Dont tighten it up too much cos youll snap the base though
Pompey306mark Wrote:I still have mine, and I dont have an aerial, no more. Been removed and filled in. No idea where mine is coming from, maybe a leak from the sun roof into the area where the aerial use to be.
Luckly mine dont have a sun roof.
I checked again there was even more water in the car this time. But its not leaking were the aerial was this time. I looked around and found the passanger door the rubber seal been cut also part of the metal lip. I could see it this time were it was dripping in on the floor.
So a new rubber seal and fill the gap and it should all be sorted now.
I got a front passanger side door rubber in good condition from the scrap yard £2. The water leak all sorted now at last.
  Water leak in rear of estate pug306driver 8 5,178 10-03-2018, 10:26 AM
Last Post: pug306driver
  water leaking inside Frosty 48 27,784 09-02-2014, 09:01 AM
Last Post: mikey b
  water inside....when it should be outside Piggy 8 4,564 10-11-2013, 07:27 PM
Last Post: Piggy
