Xud exhaust
I want a straight through on the dt, and I'm getting impatient.
Having a decat - mid box - mid box is straight through right?
Or did I miss something with these backboxmidbox swap around?
Or what's the cheapest way to straight through? Over the counter parts? Welder? Silicon pipes and exhaust?
Also what's the standard width of a dt exhaust?
(31-07-2013, 06:08 PM)Matt Wrote: I want a straight through on the dt, and I'm getting impatient.
Oh Matt..
Silicone pipes? For an exhaust?
Samass' genius idea haha
Omg really?
Have a look in my project thread, i had a full straight through exhaust made from the turbo back at AA silencers in Stafford, if your anywhere near there? was only 86 pounds anyway Smile
Blaze '6 and Blaze D-turbo!
Nah I'm on the Isle of Wight, welders and resources are low. It's a shit tonne harder to get anything done here!
yep silicone was my idea, mainly cuz that's all i had lying around and couldnt be arsed doing it properly, it was at the back, and its rated to 200 degrees anyway, it worked.
also matt, f*cking fail, exhaust in the interior section? noob
Is your back box the type with the hanger that goes all the way round in squiggles (so you could knock it off in 1 piece)?
If it is get a mid section (on of the xantias has a mid with no box), knock the hangar off the standard box, get a massive jubilee to tie the midsection to the hangar and cut to the appropriate length.
No need for welding or complicated tools.
Also as Samass says; learn to forum noob Smile
It's in interior/exterior and ice, last time I checked, exhaust was exterior.
It's just the backbox really, xantia had a straight through mid? Does it Fit the same as a 306 mid? More or less the same design?
405 has a straight through mid AFAIK too.
Its pretty much the same but different. However you could use it to make a straight through back box.
(01-08-2013, 08:30 PM)Dum-Dum Wrote: Its pretty much the same but different.
Brilliant.
lol
lmao
Chris you're a special one aren't you..
