Lower Engine Mount Fork
So the fork that goes onto the lower engine mount has a rubber bush in. Does anyone make this in billet aluminium? I can't seem to find anything on 't'interwebs.
x
Have just found this. Cant make out if its aluminium of hard rubber though Huh
Quote:• Hard Nylon compound with metal sleeve
• Eliminates unnecessary movement
HTH
Wouldn't be hard to get one made up if your in need of one.
Alright smartarse! Just 'cos I didnt click the features button lol.
Im more after a billet aluminium piece. Does anyone know if ripp makes these of anyone?
Can't remember him ever mentioning the fork bushes tbh.
Looking at the picture on the kamracing site, i know it says for 306, but the one pictured isn't? The fork bush should be orientated perpendicular to the lower mount arms. Might just be an error with the site though.
This is a very valid point that you make...
I hadn't noticed that, hopefully the part could be the same diameter etc. therefore fit? But if its rubber I'm not interested. Rubber splits. Metal doesn't lol.
Get one made by an engineering company, anyone with a lathe can do it. Here's the measurements.
Outside Length 28 mm
Inner Length 34 mm
Inner Diameter 12 mm
Outer Diameter 30 mm
Chris, you are a lad. Cheers babe x
Repped
  Top engine mount Mighty306 6 6,332 12-10-2017, 03:24 PM
Last Post: cully
  Clutch Fork Bushes 1997 GTI6 KevinTW 16 11,144 12-08-2016, 10:32 PM
Last Post: DeeTurbo
  Bottom engine mount fork bush DeeTurbo 5 3,818 08-07-2016, 10:24 PM
Last Post: Jonny81191
