Removing rear disc calipers
The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thx_active" - Line: 275 - File: inc/plugins/thx.php PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php 275 errorHandler->error_callback
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 43 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 43 errorHandler->error_callback
/showthread.php 1651 eval
Could someone please give me a step by step on how to remove the rear calipers as im in the middle of lowering my beam and need to ge tthese off so that I can get the trailing arm out fully.
Or if anyone is in Somerset and not doing anything today feel free to pop over and help please haha.
Thanks!
[Image: Foxy2.jpg]
Remove the hard brake pipe and unbolt mate.
[Image: Atterz.jpg]
WHat the 4 big bolts?
[Image: Foxy2.jpg]
Foxy-jim Wrote:Could someone please give me a step by step on how to remove the rear calipers as im in the middle of lowering my beam and need to ge tthese off so that I can get the trailing arm out fully.
Thanks!
Two big bolts on the inside of the mounting bracket (round the back of the calliper when looking from next to the car) remove those and the calliper will come off in one Smile
Team Orange Engine Bay
The firther in the arch?
[Image: Foxy2.jpg]
the two that go through the sliders, the two holes on this one
[Image: 0204103277.jpg]
If you remove the other 2 big bolts though that removes the pads out if the way too Smile
ok cheers, just given them a go and they are solid!
[Image: Foxy2.jpg]
Foxy-jim Wrote:ok cheers, just given them a go and they are solid!
well yeah, you don't want you calliper falling off when you brake do you lol
I would rather they were really fecking tight TBH Tongue
Yeh they will have thread lock on them as well so get a bar on there
[Image: SDC10442-1.jpg]
One is off. Will do the second one then time to rebuild and lower! Whats the easiest way to get the trailing arms back in?
[Image: Foxy2.jpg]
Same way you got em off ha ha big hammer lol
Though probably not best, wait for anpther suggestion ha ha couldn't get mine all the way on without it though ha ha
I cant even get it to sit at a height. It just keep sagging down!
[Image: Foxy2.jpg]
Did you mark the arm before taking it off, it will only go in 40 mm ish increments
Ye I measured how far it sat normally.
[Image: Foxy2.jpg]
As Jonny says, (unless you have removed the torsion bar fully, which I guess you haven't) you can only adjust it in 40mm ish increments!
hold it in the sort of position you want then wiggle it around it will go on
Got the brakes off, pulled the torsion bars right out, then re-inserted but had to hammer a bit to get them on!
[Image: Foxy2.jpg]
You probably already know but just incase, the piston will need to be wound back in on rear calipers rather than just pushed when you come to put them back together. Smile
Didn't know that. They are on now. Will see what happens!
[Image: Foxy2.jpg]
Toms306 Wrote:You probably already know but just incase, the piston will need to be wound back in on rear calipers rather than just pushed when you come to put them back together. Smile
Unless you fit new pads &/or discs they shouldn't need moving at all and will just bolt back on though Smile
They just went straight on!
[Image: Foxy2.jpg]
Foxy-jim Wrote:They just went straight on!
In which case don't worry about it, just remember it if you fit new pads lol
Will do! Just been for a drive and they were absolutely fine!
[Image: Foxy2.jpg]
True, if it was me I'd have probably whacked some new pads in at the same time though, unless they're fairly new already.
They have fairly new discs and pads already. Don't see the point in spending money pointlessly when I don't need too!
[Image: Foxy2.jpg]
Foxy-jim Wrote:They have fairly new discs and pads already. Don't see the point in spending money pointlessly when I don't need too!
Thats alright then, I only meant if they were old and shite (like the ones on most 306s lol!)
Haha ye that's cool. Na if they were bad I would have changed them. Would rear do things properly then make it a death trap!
[Image: Foxy2.jpg]
  Rear brake calipers Welshy_Pete 2 2,798 19-03-2017, 07:17 PM
  Rear axle - drums to disc Dreijers 9 5,383 18-08-2016, 10:42 PM
Last Post: xanax
  Any tips for undoing rear bleed nipples on calipers? Tom85 18 8,015 27-06-2016, 07:39 PM
