Rear brake calipers
I have changed the rear discs and pads on my 306 hdi due to one side pads discs warn.
So I checked the calipers other side was fine 2 bolts moving smooth and winding caliper in and out.
The other side out of the 2 bolts 1 was not free moving sliding so greased it up and got it free so both worked also winding caliper in out out ok to.
But its still sticking slightly there a rubber boot with the arm for handbrake cable going in to it I think it might need greasing up in there?
Try removing the pistons dust boot, take the piston out a bit and use a toothbrush or similar to clean around it, then wind back in and replace boot. Sometimes small amount of debris gets in there and causes sticking.
[Image: 20120704_212316.jpg]
Is the handbrake mechanism going all the way bacl to the stop?
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,342 18-04-2019, 10:14 AM
Last Post: Mighty306
  Uneven brake drag on rear wheels balkan_bozo 2 4,081 21-10-2018, 11:10 AM
Last Post: balkan_bozo
  Rear brake compensator leaking Ben 4 6,065 24-04-2018, 07:11 PM
Last Post: Ben
