05-07-2013, 10:32 AM
Has anyone got a part number for his it's the rubber one on top of then engine thanks.
Oil breather hose
05-07-2013, 11:58 AM
Oil Filler to Rocker Cover Breather Hose? Peugeot: 1180 86
Only know this because I bought one recently
05-07-2013, 12:47 PM
Yes that's it cheers dude
05-07-2013, 03:24 PM
how much are they? mine's been split for ages . .
16-07-2013, 08:50 AM
Does anyone have the dimensions of this hose please ?. It's a weird one because it goes from a large end then shrink's down into a small pipe.
16-07-2013, 06:41 PM
Well worth buying new I broke a few down the scrappy before I found a decent one. Didn't realise they were that cheap
16-07-2013, 08:48 PM
Yeah, always go brittle as f*ck and break, worth replacing!!
17-07-2013, 10:06 AM
suffers the same as injector leak off pipes.
18-07-2013, 11:50 AM
I bought mine £7 something from peugeot
07-03-2014, 03:41 PM
BUMP - thanks, needed the part number!
07-03-2014, 04:52 PM
08-03-2014, 09:51 AM
(07-03-2014, 04:52 PM)r3k1355 Wrote:(05-07-2013, 03:24 PM)Mattcheese31 Wrote: how much are they? mine's been split for ages . . don't you lose quite a bit of oil out of it mate? . . . . if we're on about the same bit you will do . .
08-03-2014, 09:57 AM
08-03-2014, 10:03 AM
(08-03-2014, 09:57 AM)silverzx Wrote:(08-03-2014, 09:51 AM)Mattcheese31 Wrote: don't you lose quite a bit of oil out of it mate? . . . . if we're on about the same bit you will do . . exactamundo . . . .
08-03-2014, 01:41 PM
(08-03-2014, 09:51 AM)Mattcheese31 Wrote:(07-03-2014, 04:52 PM)r3k1355 Wrote:(05-07-2013, 03:24 PM)Mattcheese31 Wrote: how much are they? mine's been split for ages . . The pipe connecting the plastic oil dipstick bit to the TMIC?? No mine occasionally lets out some oil vapour, which causes the odd buttock clenching moment as it looks just like smoke coming from under the bonnet. but no it doesn't spray out of mine. (my stat has been removed btw, the engine runs between 70 and 80 deg, I can't be assed to fix it)
08-03-2014, 01:48 PM
(08-03-2014, 01:41 PM)r3k1355 Wrote:(08-03-2014, 09:51 AM)Mattcheese31 Wrote:(07-03-2014, 04:52 PM)r3k1355 Wrote: Mines been completely missing for even longer. no not the tmic mate it connects to the engine/rocker cover . . .
18-03-2014, 12:04 PM
Bump, anyone got any tips on how to access it for replacement without ripping half the engine apart?
18-03-2014, 12:08 PM
It's right at the top of the engine? Just pull the TMIC off.
18-03-2014, 12:54 PM
No curt.. Just no..
Tmic is off. The bastards behind the fuel filter housing!
18-03-2014, 01:05 PM
You're not trying hard enough then, it's a piece of piss. It's not behind the fuel filter housing, it connects to the dipstick/filler housing.
18-03-2014, 01:09 PM
Guess I'll find out when I get to the car. Happy days if it's a piece of piss.
18-03-2014, 01:33 PM
I find it easier to remove the end glowplug line, can be fiddly to get it onto the back of the oil filler housing
oil out of breather under hard cornering | zx_volcane | 9 | 2,936 |
19-07-2017, 11:45 AM Last Post: zx_volcane |
Gearbox Breather | maxaret | 21 | 4,025 |
27-03-2016, 10:20 PM Last Post: bigcheez2k3 |
Breather hose | billythekid | 5 | 1,504 |
18-03-2014, 12:18 PM Last Post: padge |
