19-06-2013, 06:12 AM
Should there be a gasket on a xantia inlet manifold where the elbow bit goes on for the pipe work. This is where I'm on about
Xantia inlet gasket
19-06-2013, 06:16 AM
I would think so....
if not, flange sealant?? Wishes for more power...
You no there is you looked at mine. metal to metal wont seal 20 psi plus will it ...
19-06-2013, 02:58 PM
Just sand both sides down smoothly with some 400 grit on a sanding block. Then it will seal.
19-06-2013, 03:02 PM
(19-06-2013, 02:58 PM)306Puggy Wrote: Just sand both sides down smoothly with some 400 grit on a sanding block. Then it will seal. Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
19-06-2013, 03:08 PM
19-06-2013, 07:47 PM
19-06-2013, 08:08 PM
(19-06-2013, 03:08 PM)Seb_Ryan Wrote:(19-06-2013, 03:02 PM)Grant Wrote:(19-06-2013, 02:58 PM)306Puggy Wrote: Just sand both sides down smoothly with some 400 grit on a sanding block. Then it will seal. x3 Wishes for more power...
19-06-2013, 11:17 PM
i just used some flange sealant for mine bud, holds fine at 25psi
20-06-2013, 04:57 PM
He has a metal elbow so does not have the o ring
20-06-2013, 06:29 PM
Cut one out of cereal box lol? Bit of blue hylomar, job jobbed :p
20-06-2013, 06:52 PM
I can vouch for a bit of gasket paper (cereal box)
Fitting Xantia Inlet | Nathan1305 | 7 | 2,066 |
10-04-2015, 12:13 PM Last Post: Nathan1305 |
Xantia manifold gasket | Nathan1305 | 2 | 1,528 |
06-04-2015, 07:57 AM Last Post: Nathan1305 |
Inlet Manifold Gasket | ally406 | 6 | 2,113 |
11-11-2013, 10:37 AM Last Post: ally406 |
