fitted a dump valve now lossing boost
hi there everyone ive just fitted a bailys dv36 twin piston dump valve to my dturbo got it all on the car with electric vacuum pump and micro switch after a big headache lol only problem now is my car was boosting 16psi before dump valve now only seem to be getting 11psi can any one help with this thanks Alistair
Moved as this is clearly not a guide...
My advice would be to remove the dump valve from your diesel. Other than that... there must be a leak somewhere.
I'm with Curt tbh, dump valves on diesels just dont sound right. Best bet is to just do away with it. If you're still low on boost after that, check the usual suspects for leaks. Smile
a dumpvalve on a diesel IS a leak
(14-06-2013, 05:04 PM)ozonehostile Wrote: a dumpvalve on a diesel IS a leak
Totally agree waste of time on a derv n sound shit as out of time get a big blower instead
[Image: J5hxCcC.jpg]
Agree with all the above, I had one and removed it a week later as it just did't sound right.But to answer your question, check the gasket on the tmic if you removed it, check all jubilees, etc.....
HDi Cabby Project Click
^^^ THIS ^^^ FFS, aaaaahhh diesel dump valves Doh
(14-06-2013, 04:01 PM)ingham66 uk Wrote: hi there everyone ive just fitted a bailys dv36 twin piston dump valve
And you ask why you have a leak?
I had one had to switch it off if wanted to boost over 22psi if its bot holding 16 then its not a twin piston one for a start
Or its f*cked
errr....you have to created the vacuum from somewhere to make the dumpvalve work....tells you something about why you dont and shouldnt have a dumpvalve on a derv
  Dump valve on a diesel? 306pc 14 8,232 29-07-2014, 04:34 PM
Last Post: ADV_93
  dump valve leaking oil DTurboTom 41 19,238 31-12-2013, 08:40 AM
Last Post: Chris_90
  dump valve bayley 7 5,190 27-05-2013, 12:32 PM
Last Post: bayley
