06-06-2013, 10:03 PM
waxoyl is it worth giving the underside a coat ?
fors and against please
thoughts on waxoyl
06-06-2013, 10:04 PM
Fors: tidies it up, makes it more likely to pass an MOT as the tester will see it and assume you cherish it, if done properly will keep everything from rotting
Againsts: makes a mess EVERYWHERE. Sticks to everything. It's black /Rowell
06-06-2013, 10:06 PM
Use it inside the chassis rails, yeah. But elsewhere I'd look at using something that sets hard and isn't like anti vandal paint
06-06-2013, 11:34 PM
I highly rate the stuff, not really necessary on a 306 but on older cars certainly the injection kits they do to protect sills and other vulnerable bits are brilliant
06-06-2013, 11:38 PM
Yes its brilliant stuff but you need to cover your entire driveway in a plastic sheet then cover yourself in clothes you never want to use again oh and cover your face and hair cos otherwise you'll look like a dalmatian for weeks.
Use the big can with the trigger spray cos the aerosols don't last long and make even more mess. Top stuff IMO, would be coming from Hammerite really.
07-06-2013, 06:18 AM
As above really, amazing stuff, just be prepared to get filthy!
07-06-2013, 06:23 AM
As mentioned. I did mine recently its good.stuff but it goes.f*cking everywhere and that sprayed system is beyond useless
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
07-06-2013, 08:15 AM
Good stuff but....................... I done the whole under side of my discovery in it and it was a PITA as every time you get under it and work on it come out looking like youv been rolling in fresh tar, like Jonny says id prefer something that goes off hard (gigity) on a 306
07-06-2013, 09:04 AM
Mines set hard. Its soft enuff to scrape off but if you rub it its hard and leaves no marks unlike the brush stuff i did the engine bay with *faceparm*
07-06-2013, 11:13 AM
07-06-2013, 05:12 PM
Oooooo Before and after pictures i can do that
Before, After Good stuff but as said above you get filthy
07-06-2013, 05:25 PM
Don't beleive you!!! There is none on the drive or the trees lol!!!
Good shit bud
07-06-2013, 06:15 PM
I didnt get dirty paintingit, its when i work on the car after i seem to have to brush my face/arms/legs on it. It seems to have hardened up now though.
Waxoyl into inner sill? | unclebeast | 13 | 1,996 |
07-12-2016, 08:53 AM Last Post: tigerstyle |
2nd Thoughts | chylledapps | 15 | 3,584 |
24-01-2015, 07:50 PM Last Post: chylledapps |
Thoughts on mk1 mx5 | Jtrigga | 34 | 11,291 |
18-12-2014, 10:52 AM Last Post: Razorback_Rob |
