Dump valve set up
#31
(06-06-2013, 12:56 PM)Reginald Doe Wrote: [Image: attachment.php?aid=7593]
Mate i could tell you alot of things about them and how they are better than internal ones but nobody here listens far less agrees with me far too many people assume that because they don't NEED one that it wont be any improvement.
(06-06-2013, 01:02 PM)Ben hdi306 Wrote: So Dum-Dum do you reckon if I put a small inline bike fuel filter housing into the pipe just before the solenoid it would make it louder?
Yeah but rip the filtering stuff out first.
(06-06-2013, 01:51 PM)Reginald Doe Wrote: Honestly... on a stock engine running 14psi of boost, it isn't going to be loud!! It'll be louder if you wind the boost up, but remember you're not flowing nearly as much air as in a petrol, and you dont ever have that point where the throttle plate shuts and the air has nowhere else to go but out of the dump valve. With a diesel, if you come off the throttle, the engine is still drawing in air, so there isn't any massive quantity to vent or any massive pressure to vent either...
Yeah a 2l turbo diesel engine at 14psi flows nowhere near as much air as a 2l petrol engine at 14psi
Dump valves work fine on standard petrol cars with tiny engines and 5psi of boost so as long as you can get it to open fast enough you will make a good noise
  dump valve on hdi? charlie7543 19 7,246 10-08-2012, 02:27 PM
Last Post: 4WayDiablo
  purpose of a dump valve aaron_one 14 4,725 28-05-2012, 06:21 PM
Last Post: Ed Doe
  dump valve hdi needed quickly keithnewton 20 7,290 16-05-2012, 12:57 PM
Last Post: Mr Whippy
