Cambelt/Water pump recommendation
Jenksowls is doing my Bosch conversion next weekend, what kit would people recommend and where's best to get it?
We mostly use gates timing kits and qh waterpumps, continental are also a good kit.
Gates is what I use belt kit wise. There usually a bitch to get on as there quite tight and grippy with the power grip particles in them. Water pump just any decent brand one like QH I don't think Ecp or cpfl do gates stuff. eBay has the kits for around £80-90 mark
www.prestige-auto-care.co.uk
Cool, I'll order a Gates one. Are all the XUD kits the same? I saw one cheap that was marked for an NAD but surely it's the same?
Wouldn't cheap on timing belt. Got nine from Ni
(25-05-2013, 06:03 AM)THE_Liam Wrote: Cool, I'll order a Gates one. Are all the XUD kits the same? I saw one cheap that was marked for an NAD but surely it's the same?
Some XUD water pumps differ. I found this out the hard way.
I've got an SKF water pump here if you want it, brand new.
There's 2 different kits, they come with 2 different backing plates on the idler pulley.
I have a gates tensionor and pulley, make me an offer Smile unused, box was opened for cambelt though.
Anyone got a part number? There's about 15 different kits...
Is service box where you find the exact part number? Does anyone have it?
Here's the part numbers of the 2 different gates kits, if you look at the idler pulley on the car and then go to the motor factors you'll know which to get.
K015049XS
K025049XS
Thanks mate!
Right, ordered K025049XS, pretty sure it's the right one Smile
Bumpy, my cambelt tensioner is squeaking going to do the lot and put 11mm on at the same time, Liam did that kit work for you? Anyone reccomend a kit andor where to get it? Found one for 60quid on ebay atm
K025049XS - http://www.ebay.co.uk/itm/1-x-Gates-Powe...4ace86f1e2
The SKF kit I got from ECP came with a Gates belt.
good price there, I gave £80 for mine, though it came with a waterpump too.
Gates all the way here.
Is that the right one for xud? I'll get a waterpump on its own from somewhere.
http://www.gatesautocat.com/article/K025049XS
XUD9 seems to be listed here ThumbsUp
I get gates too
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
(08-01-2014, 01:59 PM)Tom Wrote: Is that the right one for xud? I'll get a waterpump on its own from somewhere.
Check what idler pulley you have as theres 2 different kits with 2 diff idler pulleys.
I really cba to take it all off and find out lol surely they both fit?
This is the one I'm watching at min that I'm gonna get for my engine, didn't no there was difference in idler pulley tho so not sure if it's right or not now Undecided
http://pages.ebay.com/link/?nav=item.vie...0671561646
These are the 2 different types:
[Image: T42068.jpg]
[Image: T42069.jpg]
(26-05-2013, 09:11 AM)THE_Liam Wrote: Right, ordered K025049XS, pretty sure it's the right one Smile
It did mate, mines a D8A block if it helps.
Mine is as well! Sweet.
  DW8 Timing belt cover / water pump bolt size? jamesgmg 13 4,723 06-07-2017, 03:41 PM
Last Post: Mighty306
  water pump help sb194114 4 1,111 25-03-2015, 10:28 AM
Last Post: cully
  water pump differences? ash23 1 979 11-06-2014, 05:20 PM
Last Post: ConorTRG
