19-05-2013, 07:50 PM
What are the symptoms if a ball joint failing?
2000 2.0 HDi Estate
ball joint failure symptoms
19-05-2013, 07:53 PM
knocking clonking from the front
less responsive delayed steering car wandering around the road
19-05-2013, 08:11 PM
uneven tyre wear is another good indicator
19-05-2013, 08:52 PM
(19-05-2013, 08:47 PM)rd070707 Wrote: hmmm this could me my problem, how do you test it? Jack it up and see if there is any play up and down in the wheel..
Blaze '6 and Blaze D-turbo!
19-05-2013, 09:09 PM
Yea try pushing the top while pulling the bottom and vice versa if you feel play then get em changed
19-05-2013, 09:27 PM
you may find as well that the hub may become f*cked. thats whats happened to mine and it sounds and feels terrible at the moment
21-05-2013, 05:52 PM
I get a knocking but no play in the wheel when tested as above. Seems to knock at lower speeds more so. I've already changed the drop links.
2000 2.0 HDi Estate
Ball joint/ Hub to strut pinch bolts | Uberderv | 7 | 2,446 |
04-01-2018, 11:40 AM Last Post: Mighty306 |
fitting a front suspension ball joint | impotentials | 3 | 2,035 |
29-10-2016, 05:46 PM Last Post: Poodle |
Bottom ball joint sizes | Xsikid | 4 | 1,663 |
04-05-2016, 05:45 AM Last Post: Paul_13 |
