Check strap/door advice required
advice required please...do i repair or replace????
my g/f lost the the pin that connects the yoke on the front drivers door to the check strap - the current check strap is fine apart from that.
do i A) buy a complete 2nd hand check strap or B) do i just buy a pin and repair what i currently have?
the pin i found is this one...????
The check strap is obviously more than the price of the above pin posted..
cheers
[Image: siggy1.jpg]
The pins are only cheap from pug lol
Just replace the roll pin, job done
First things first DO NOT BUY THAT PIN!!!!!! Its a f*cking rip off! Theyre >£1 from pug... Secondly, ph1>ph2/3 pins are totally different and yours being a ph1/ph2 bastard child that it is, Id have no idea which strap they used. Ive replaced the ones on my miami before, so I know it can be done for ph1
(28-04-2013, 09:22 PM)Curt Wrote: Just replace the roll pin, job done
was thinking that curt when i saw the pin listed
(28-04-2013, 09:23 PM)Connor Wrote: First things first DO NOT BUY THAT PIN!!!!!! Its a f*cking rip off! Theyre >£1 from pug... Secondly, ph1>ph2/3 pins are totally different and yours being a ph1/ph2 bastard child that it is, Id have no idea which strap they used. Ive replaced the ones on my miami before, so I know it can be done for ph1
what's the difference between the ph1 & ph2/3 check straps? the issue i have with MYA is she is 96, registered early 97 but a mixture of ph1&2 parts so buying anything is an episode !!!
[Image: siggy1.jpg]
If they're only a quid... get one of each?
  Fitting Door Strap Arrester Pin partybish 6 4,520 29-09-2017, 07:18 PM
Last Post: partybish
  Check strap Sheered PugRory 3 2,728 24-02-2016, 02:50 PM
Last Post: Jake
  Front Door Check Strap Welshy_Pete 2 2,519 04-07-2013, 11:47 PM
Last Post: Stephen
