Cully's Bianca 6 R150 YVM
(16-04-2016, 07:26 AM)zx_volcane Wrote: Any luck getting the diff back in?
Takes a little getting used to, hitting standing water at speed is an interesting experience.
refitting is todays task aslong as the rain holds off Wink
Final drive half housing bolts, M10; 41Nm 30lbft
Final drive half housing bolts, M7; 12Nm 9lbft.
Speedometer pinion adaptor; 12Nm 9lbft
Final drive extension housing bolts ; 15nm 11lbft
GTI6 Info
well i must say that was easier than i expected!
just got to put it all back together now
Smile
GTI6 Info
Rain stopped play
engine is back on the top two mounts, diff is all torqued up with no side to side end-float which is good, gear linkages are on
bought a new exhaust washer and some new pinch bolts for when i refit those bits
GTI6 Info
he he! i now have a drivable car that you need to wrestle with *grins*
oh boy is it different to drive off of the straight line and there is torque steer to correct too
time to start learning to drive again Wink
MOT expires 15th may so ive booked it in for tuesday 19th april for a 13 month ticket Smile
well if it passes
GTI6 Info
i am insanely jealous of this. always wanted one. good work not dropping the subfrme out man
(16-01-2016, 11:25 AM)cully Wrote: Iv'e worked out the issue with connecting to the plastic hard-lines! yeh!!
plastic hard-line > 6mm Pipe inserts > 8mm compression hard line to AN6 adapter
the pipe inserts give the plastic tube rigidity so the compression olives don't squash the plastic pipe
[Image: 20160116_110943.jpg]
[Image: 20160116_111030.jpg]
Can you give me a link to these bits please? The only bits I can't find to fit the lines.
I've got everything else, just can't see how to connect to the hardlines properly. It may end up in a epic bodge otherwise haha
http://306oc.co.uk/forum/showthread.php?...#pid575171
2 X 6mm Pipe inserts (£4.77 for 10) eBay item number:271143300843
2 X 8mm compression hard line to AN6 adapter (£10.60 for 2) eBay item number:301210932829
GTI6 Info
Nice one mate that's perfect!
http://www.ebay.co.uk/itm/AN-6-AN6-STRAI...0672198035
Mmmmmmm LSD...
(18-04-2016, 09:38 AM)silverzx Wrote: Mmmmmmm LSD...
yes Mmmmmm
begining to like the No understeer in corners...POWER!
but the launch torque steer is quite a handfull to wrestle with not expecting it Big Grin
GTI6 Info
yes Mmmmmm
Ahh yeah, well if it's really that bad I'll take it off your hands for you.  Itwasntme
ATB not lsd Wink
(18-04-2016, 02:06 PM)welshpug Wrote: ATB not lsd Wink
Active Time Battle?
[Image: FFVIIbattlexample.jpg]
Ahh... FF7... Good times.
"cut and paste"
Quaife Automatic Torque Biasing (ATB) limited slip differential.
Quaife (ATB) limited slip differential automatically biases the torque across the axle to the wheel with the most grip. Unwanted wheelspin and slip are greatly reduced, resulting in less understeer on front wheel drive machine,
the Quaife ATB limited slip differential also delivers significant performance benefits during heavy braking. In this situation the Quaife differential’s inherent torque transfer characteristics work in reverse to transfer torque away from the locking wheel. This enhances deceleration, delaying the intrusion of electronic ABS systems and allowing drivers to brake later and deepe
GTI6 Info
Very jealous of the LSD.
MOT is booked for tomorrow!
I've checked the easy stuff
lights,belts,wipers,fluids,tyres,lamps
freed off the rear compensator and adjusted the rear pads up
so its suck-it an see time at 9am so a quick raz around the roads to warn things up then hand it over
GTI6 Info
Learnt something there, never thought about the LSD being useful under braking. Smile
Just got back from the MOT!
PASSED with NO Adisorys Big Grin
bring on show season and some more track time!
car has done 5087 miles since last MOT
GTI6 Info
well done! Big Grin
(19-04-2016, 10:29 AM)cully Wrote: Just got back from the MOT!
Now, switch in a spare cluster of clocks... Wait until a month before the next MOT and put the originals back in... Wink
Winning!
after passing its MOT in such a fine fashion i decided to start sorting the paint for show season again
gave the car a good wash and clayed the paintwork followed by another wash and a quick wax
GTI6 Info
I just cant get myself into cleaning at the moment.
(19-04-2016, 09:02 PM)Dum-Dum Wrote: I just cant get myself into cleaning at the moment.
Me neither.
It will get jetwashed and a bucket of soap, maybe, before I make my way. It usually rains on route anyway.
had to be done sorry
car was beginning to look like a Dalmatian with all the tar spots
GTI6 Info
Holley Balls need a clean pair of pants!
dont underestimate torque steer at high speed it certainly puts a wriggle on!
Confused
just stepping off the gas made the car angry!
GTI6 Info
it shouldn't do that.
(23-04-2016, 04:53 PM)welshpug Wrote: it shouldn't do that.
I wished it didnt!
pulled 5th to the limit then changed to 6th  powered fine then lifted off gas and the car snaked!
I didnt like that Sad
more power or a trail of brakes settled it though
GTI6 Info
No.....atb diff shouldnt so that at all surely!?
  cully's XU10J4RS cully 11 5,111 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 47,502 16-04-2016, 04:14 PM
Last Post: cully
