Cully's Bianca 6 R150 YVM
(10-01-2016, 09:15 AM)cully Wrote:
(10-01-2016, 09:00 AM)roland rat Wrote: Good news regarding the rust situation as all that is easy to take car of.
Sure Adam had me rip the aircon out as it was f*cked many moon ago.
What engine is going back in?
scroll back about two pages for the engine
i refreshed a std engine rings bearings seals the works and have fitted that with lightened flywheel and pulley Smile
the air con was still in this car when i bought it now there is none left in the engine bay as ive removed all the pipework and compressor
Doh,I was confused as I didn't see that you pics had been quoted
Lovely to see it in good health love a white 6 and miss my old phase 2 one to this day
Iv'e worked out the issue with connecting to the plastic hard-lines! yeh!!
plastic hard-line > 6mm Pipe inserts > 8mm compression hard line to AN6 adapter
the pipe inserts give the plastic tube rigidity so the compression olives don't squash the plastic pipe
[Image: 20160116_110943.jpg]
[Image: 20160116_111030.jpg]
GTI6 Info
ah tidy job
my arm was forced i had to commit myself as a found another leak, where the white tube enters the plastic hardline Sad
anyway all went well replacing the fuel rail and fitting the adaptors to the plastic hardlines
the olives were a little tight on the pipe but i sorted that, all on tested been for a run and no leaks
happy bunnie Smile
[Image: 20160116_160502.jpg]
[Image: 20160116_160444.jpg]
[Image: 20160116_161446.jpg]
GTI6 Info
Looking good sir!
road trip to lyme regis earlier for some work to be done via our resident beam builder Stef Smile
I've had 21mm bars fitted and the rear ride height adjusted so its time to learn the car again
was a totaly different car to drive home a lot more forgiving in the corners
Thanks Stef Smile
[Image: 20160117_100203.jpg]
[Image: 20160117_104029.jpg]
[Image: 20160117_104052.jpg]
[Image: 20160117_110405.jpg]
New height
[Image: 20160117_133026.jpg]
old height
[Image: DSCF1043.jpg]
GTI6 Info
Nice to see you today Paul,
Beam came apart easier than i was expecting considering it was built around 3 years ago. Arb flags moved freely too which was even better they can normally be nice a crusty.
I mocked up the dummy shock prior to removing the old tb's for an idea on height, We agreed to put the new bars back in at the same height measurement taking into consideration of the bigger bars and seemed to come off well. Gave Paul complementary new shock bolts and new tb bolts as the previous builder had made a balls up of it.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Much better ride hight! Always felt it was too low at the back end.
JP
we didnt actualy change the ride height, the 21mm bars being stiffer has made it sit higher which has made a big bifference in the handling,
the car seems more settled and less skittish in the corners, you can adjust your power in the corner now without it twitching its ass like a rabbits nose Smile
GTI6 Info
I washed the car yesterday she was looking so sweet i had to take her out for a drive today!
now she is back to how she was.....Dirty!
the 21mm rear bars and the ride height of the rear of the cars has transformed the handling
its so much better.
but.......
its changed the character of the car some of the IM GOING TO KILL YOU has gone
meaning i can drive it faster as its more controllable/predictable ,
I'm not sure if this is a good thing
maybe i should hand my license over before its shot with points
JOKIN!!
cant wait now for the track day I have booked for the 20th Feb
**Please don't snow**
things to do before then..
Nut and bolt check
check brakes/fluids
change oil as its done nearly 3K since the rebuild
check track tyres
build up a fluid/spares pack to take
GTI6 Info
glad your happy with how it handles now, really does make a huge difference! Smile
05' Evo 9 IX GT
Team eaton.
finished off my fuel pipes today by making two stand off clamps that replace the bolts on the top engine mount yoke,
these will do away with the cable ties and hold the pipes rigid car side
makes a neater job!
GTI6 Info
I like that.
Tidy install.
Looks good that bud if it were me that supply line would be shortened slightly so that the gap between the two pipes matched all the way around Wink
so what parts do i need to buy to hold pipes like that?
Looks ace
Now make us a group buy so we can all have them Big Grin
[Image: Cn91r40h.jpg]
group buy No!
its all on ebay cheap as chips well nearly
so the shopping list for you goes like
2 X AN6 weld on steel fitting (£5.98 for 2)
4 X AN6 BLACK 45 Degree Swivel TEFLON PTFE Fuel Oil Braided Hose Fitting (£11.95 for 1)
2 mtr AN6 5/16" 8MM Stainless Steel Braided TEFLON PTFE Fuel Hose (£9.95 per Mtr)
2 X 6mm Pipe inserts (£4.77 for 10)
2 X 8mm compression hard line to AN6 adapter (£10.60 for 2)
2 X AN6 13.4MM Braided Hose Separator Clamp (£9.90 for 8)
things to watch though
the compression olives are tight to get over the plastic hard line,
the 6mm inserts will need the front leading edge filed so they enter the plastic pipe without digging in ,they are tight entering the olive once inside the pipe,
the hose clamp stand offs i made from the pipe clamp and a inlet manifold stud
i tapped the bottom part of the clamp to 8mm so the stud screwed into the lower of the hose clamp
this was locked with a 8mm nut
the top part of the clamp secures via a m4 socket bolt so i drilled and tapped into the top of the manifold stud 4mm tread
the whole thing just replaces the existing yoke bolt and locks with a M8 nut
i also cut a thin strip of rubber to grip the pipe in the clamp so it wont wear the steal braid
GTI6 Info
great work. I wonder if i can just get an AN6 fuel rail for the jenvey bodies.
and..........Balls i now have a slow puncture on the front that needs sorting  Angry
GTI6 Info
bring it to meeeee lol
05' Evo 9 IX GT
Team eaton.
(31-01-2016, 09:03 AM)Stef205 Wrote: bring it to meeeee lol
your a long way to go for a puncture.....
but thanks for the offer Wink
GTI6 Info
yeah but ive some michies with your name on them Wink
05' Evo 9 IX GT
Team eaton.
i would of been better driving to you!
Michies you say?
i feel like national tyres have had my pants down
robbing uncaring bastards
would not recommend the f*ck nugget at the Tiverton Branch that served me
GTI6 Info
I just try not to use chain tyre shops at all. We can use either Kwikfit or ATS with the work cars and they are both just utterly useless. Im sure they purposely employ the brain dead!
i can give you 25% off 4x or 20% off 2 michies atm Tongue
05' Evo 9 IX GT
Team eaton.
Lol, you didn't read the small print Paul, it does say on them vouchers that you'll be charged valve and balance!
been to pick up some parts that were local and cheap
bonnet,grill,hocky sticks,windscreen scuttle
all in the correct colour but dirty eeeeeW
Oh! and a bonnet does fit in a 306 Smile
GTI6 Info
has been a good dry day today so have set about checking the car over before my trackday on saturday
Ive removed the laguna splitter and fitted a Std GTi6 version
fitted a new fuel filter as i haven't changed it since buying the car.....Oops
also freed up the rear brake bias valve on the beam as that was siezed again
oh when it packs up altogether i found a new one Wink
just waiting for a set of Mintex Racing M1155 front pads to turn up then ill fit them before saturday
I'm taking a set of Rainsport3 tyres and ither my A048's to kill off or a set of new scrubbed R888's
need to keep an eye on the weather though Smile
GTI6 Info
Guna be coooold. So whichever warms up the best!
My rear end AD08Rs let go on friday at like 25mph, just coz cold. Was dry road lol
  cully's XU10J4RS cully 11 5,124 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 47,603 16-04-2016, 04:14 PM
Last Post: cully
