electronic boost controller
Anyone have one?? Worth getting? Does turning the boost up to 28psi make a bigg gain or any gain?
I wouldn't touch the boost until you get an intercooler as you'll just melt the turbo with really high exhaust temperatures without one.
Im not sure they will work as they need a vacuum?!
(22-03-2013, 10:52 AM)dan wiltshire Wrote: Anyone have one?? Worth getting? Does turning the boost up to 28psi make a bigg gain or any gain?
28psi on the stock hdi turbo, be lucky if it last longer than 30 seconds
(22-03-2013, 12:10 PM)Piggy Wrote: Im not sure they will work as they need a vacuum?!
They rely on a solenoid valve between the boost feed to the actuator, so it stops the actuator receiving boost pressure until the electronic controller allows it. So if you unplug it, itll just run stock boost pressure..
But doesnt work great with diesels, soon as they get to any decent performance level, they usually blow the wastegate open, so you have to tension the actuator anyway...
  Boost controller GFB G-FORCE II loli_04 6 5,093 18-03-2017, 11:03 AM
Last Post: loli_04
  electronic boost controller ??? Donkeybubles 5 3,635 16-07-2015, 03:41 PM
Last Post: JTaylor2005
  manual boost controller and egr blank plate fitting, please help dirtyboost89 6 4,409 02-03-2015, 11:50 AM
Last Post: dirtyboost89
