hdi fault code help anyone
i got my dad in to 306s now he went and got a hdi it got two fault codes come up one is
p0560 system voltage
and the other one is
p0380 glowplug/heater ckt
also theres no power in the injectors
Voltage will either be your battery or a bad earth, the ecu considers this a serious enough issue to prevent starting, so you wont see voltage to the injectors until you fix the problem. Try it with a known good battery amd see how you get on. Dont worry about the glowplug circuit too much for now, the engine doesnt need them to run.
Thanks I give it ago
  Peugeot Fault code Welshy_Pete 8 5,338 09-08-2017, 08:09 AM
  Glow plug fault code? JTaylor2005 2 2,667 22-05-2016, 12:22 PM
Last Post: JTaylor2005
  Clarke OBDII Fault Code Reader Toms306 62 52,203 11-10-2012, 10:44 AM
