04-03-2013, 07:39 PM
Does this turbo bolt onto any standard xud manifold? Also are any original oil lines interchangeable
Thanks
Thanks
gt1752 saab turbo fitment
Thanks
04-03-2013, 08:07 PM
1) do you have an XUD manifold to spare
2) do you have any oil lines to spare?
Phaes 1 GTI 6 - Onyx Black
04-03-2013, 08:09 PM
I'll put it bluntly- No. It's a custom job, some turbos are very close to near bolt-ons though.
Stage 2 XUD Sedan
04-03-2013, 08:23 PM
Is there anything bigger/better than a t2 that's pretty much a bolt on job
04-03-2013, 09:47 PM
Don't want a td04 it will only throw a rod. Something just to push say 24psi without too much strain
04-03-2013, 09:48 PM
my standard kkk is at 24psi...standard 9mm pump and lda...goes well and no issues
04-03-2013, 09:49 PM
It could throw a rod at any point. Some last for ages and some blow at stock power.
04-03-2013, 10:12 PM
(04-03-2013, 09:49 PM)Tom Wrote: It could throw a rod at any point. Some last for ages and some blow at stock power. This^ Totally stock xud's throw rods. If you just want basic bhp (120-140) then stick with a stock t2 or k14. If you want more power with little homework go for a CJ td04 combo. If you want more power and don't mind doing some research and you are handy with a mig there are loads of choices
04-03-2013, 10:17 PM
My gt20 wasn't far off, just had to drill and tap three holes in the manifold.
04-03-2013, 11:12 PM
04-03-2013, 11:34 PM
Not really, down to casting defects, random, and unpredictable
05-03-2013, 12:07 AM
(04-03-2013, 11:34 PM)sammykins Wrote: Not really, down to casting defects, random, and unpredictable What he said^^, no one seems to have figured out why some last and some dont. It really is just hit and miss.
05-03-2013, 07:29 AM
Ah right. Cheers lads. What about changing the rods to HDI 1s or is there not much point?
05-03-2013, 08:18 AM
yes that helps....but there could be defects in those.
end of the day nothing is perfect...man made it Wishes for more power...
05-03-2013, 08:24 AM
or go for forged rods but silly money could probably buy 2 engines maybe more for the price of the rods
05-03-2013, 09:50 AM
If you see a set of xud rods next to hdi you can see hdi ones are much meatier. But then again people have killed hdi rods, i've heard Ruan say of a few, then Daves kill god only knows how many haha
05-03-2013, 10:48 AM
![]() You can see the hdi rod is beefier near the little end.
05-03-2013, 12:22 PM
You don't even need to consider changing rods if your not after big power - it's just not worth it. You won't see much (if any) gain in power and reliability is a debatable topic.
If your worried just stick to a standard turbo - GT15 for epic drivability, K14/T2 for bit more top end poke. Otherwise as said go for a TD04/T25. (04-03-2013, 09:24 PM)Chris_90 Wrote: Cj's adapter plates and jenks oil line and a td04 pretty much bolt on Ta for that ![]() (04-03-2013, 09:47 PM)Jimbo Wrote: Don't want a td04 it will only throw a rod. Something just to push say 24psi without too much strain Just run 24 on a TD04 then your only going to throw a rod with too much static advance or hydroing the engine or if you were to get oil into the air intake really if your not pushing big boost and high etc IMO i run 28 atm cos my manifold bolts need retappin but 24/26 id day would be good on a TD04 ive noticed improved mpg with it having bigger impeller on hotside so engines not having to work as hard, and you dont need too much boost as the flow is greater on these turbos
05-03-2013, 02:24 PM
(05-03-2013, 12:29 PM)CJ_Derv Wrote:(04-03-2013, 09:24 PM)Chris_90 Wrote: Cj's adapter plates and jenks oil line and a td04 pretty much bolt on no worrys, Im planing on running around the 22/24psi on the td04 when i get it fitted what will i be seeing power wise? 140-150bhp?
05-02-2014, 06:33 PM
Cj, you still doing Td04 adapters n lines?
05-02-2014, 08:34 PM
Holy bump batman.. almost a year ago
![]() least you've used the search button at least, you'd be better off pming CJ, but don't think you can do that till you've reached 35 posts iirc
Im in talks with my man about it as hes not been able too for a good while but can ask as theyve a new plasma cutter now which will speed it up leave with me il see what I can do
Im not on here as often due to owning a megane so different forums lol
13-02-2014, 08:36 AM
Spoke to my guy hopefully we will be making these again in the next few weeks il keep you posted
08-03-2014, 07:12 AM
Can draw around mine at home?
| Turbo fitment between 405\306 | bashbarnard | 10 | 5,743 |
02-11-2015, 07:56 PM Last Post: bashbarnard |
| GT1752 V turbo | Dturbobooost | 7 | 4,004 |
26-08-2015, 04:39 PM Last Post: Dturbobooost |
| turbo fitment | ashkid | 13 | 8,651 |
26-06-2013, 06:37 PM Last Post: ashkid |
