Turbo fitment between 405\306
Am i right in thinking that a 405 turbo will be a direct fit to a 306. Same exhaust elbow etc. Have found a good t2 on the gumtree. Will put a cheeky offer in if so.
Just to mention from my experience, and I know its a different car, but....a Xantia K14 had the exhaust elbow at a slightly different angle. Worked for me in the 206 but would of been facing the bulkhead a bit more on a 306.
My 2p.
See i fitted a k14 from a 205 directly onto one of my motors a while back and it was fine.
405 elbow and downpipes are different, 205-309-306 are the same, I.e drop a 306 1.9 dt into a 205 you would use a stock 205 dt downpipe (306 downpipe is a different curve)
So basically it wont fit cause of the angle of the dangle. Well exhaust elbow. Bollocks. Still searching for a t2 then.
http://forum.205gtidrivers.com/index.php...pic=109916
Saw this. Maybe i can fit one? Any more opinions.
pretty sure i have a T2 from a 306 if you want it, came off only because the engine was gokng into a 405, will dig it out.
(02-11-2015, 04:58 PM)welshpug Wrote: pretty sure i have a T2 from a 306 if you want it, came off only because the engine was gokng into a 405, will dig it out.
If youve got one that would be epic! Have a look. Would need it posted though asap.
https://flic.kr/p/zEAcVs
one garrett turbo from a very early 306 xldt.
cant really tell if thats a t2 from the pictures. i would assume so if it is off an early model and has the waste gate. Does it have the manifold as well?
no manifold, its the same I think?
k14 and t2 are the same. i have a k14 manifold on atm so it would be fine. how much posted for it?
  gt1752 saab turbo fitment Jimbo 28 25,423 08-03-2014, 07:12 AM
Last Post: Paul_13
  turbo fitment ashkid 13 8,643 26-06-2013, 06:37 PM
Last Post: ashkid
