Which top-mount bearings?
Can anyone recommend a pair of top-mount bearings for me please?
Mine need replacing as the offside is creaking heavily when steering is on full-lock.
What is the most budget-conscious approach to take with these?
Any real reason to spend more than the minimum?
Thanks
GSF...great price and quality...just got mine from them...
Thans for the recommendation.
I am looking at the GSF parts available, and they seem to have two have identical specs:
Part numbers: 457PC0340 and 457PC0051
Which did you go for?
Any other parts needed?
Lemforder ones come recommended, what I have on mine
SKF ones are about £50 for the set from ECP. Less with the club discount Smile
I got SKF ones from GSF...but via ebay...
http://www.ebay.co.uk/itm/380447321856?s...1439.l2649
That's an amazing price!
Are they any good?
They are SKF...not fitted them yet
Can only assume GSF doing a stock clearance
Are they the same as these, as recommended at post #34 here?
Did you buy new top mount bearings at the same time too?
the kit you have linked is the mounts and bearings. The one piggy has put up is just the bearings.
I am getting lots of creaking from the offside-front when on full lock, after fitting new coilovers and running them at a 75mm drop.
Should I replace the mounts and the bearings, or just the bearings?
Just replace the whole lot, they're cheap enough. Mine were new when I fitted my coilovers so I ruled mine out
Which kit did you go for, Curt?
Lemforder ones from my local Camberleys
  Renew top mount bearings? Flynn 4 4,636 27-12-2011, 07:02 PM
Last Post: Dum-Dum
