08-03-2013, 04:55 PM
Puggie's GTI-6 Refresh (free cars are best )
10-03-2013, 07:52 PM
Sounds like a Good car .
11-03-2013, 07:35 PM
Got a few things done today. Rocker cover gaskets on a 540. Discs pads and drop links on a swift . And a suspension strut on a mondeo.
Oh wait this is my 6 thread Got one of my black masks done today
Started on the engine clean up been at it a few days now and i am sick
Before During After It still looks a bit shit. So time to take remove the inlet manifold and have proper degrease and a lick of paint me thinks cam covers will be cleaned and prepped and painted so inlet manifold gasket and throttle body gaskets to be replaced Oh and a quick picture of the muck behind the rear lights Just waiting for a few things coming from mr postman :/ so i can get cracking on thursday Will shebe ready for pugfest/FCS? :/
26-03-2013, 08:20 PM
Did you get the badges mate?
26-03-2013, 08:43 PM
Yes mate cheers
forgot to let you know sorry
26-03-2013, 08:50 PM
No worries glad you got them!
Right big update pics to follow
Since getting the car I january replaced the following Cambelt Waterpump Tentioners Thermostat Engine mounts Track controll arms Trackrod ends Rear beam mounts Front & rear discs & pads Injectors refurbed TPS replaced Inlet manifold bung K&n apollo cold air induction kit (bwarp is epic ) Front panel powder coated black So I habe no real need to use the car in the coming months so I would be rude not to start phase 2 of the clean up Going to refurb the underside of the car from front to rear beam is coming off so is the petrol tank I am starting there working forward to the front brake likes and fuel lines will be replaced if needed So I will be using the following products Bilt hamber detox c Bilt hamber detox gel Bilt hamber hydrate 80 Bilt hamber dynax s50 anti corrosion wax U-pol seam sealer Acid etch primer Black hammeright Should have the car minty fresh by november
09-07-2013, 03:03 PM
Sounds good man. How did the car take to the injector refurb? Mines recently started to get a bit lumpy on idle and thinking it could be dirty injectors.
09-07-2013, 03:25 PM
Car is a million times smoother mate not a bad price either. A case of bud sorted the job it was running a little fast at first ecu clear quick blast on my private runway running sweet.
09-07-2013, 05:29 PM
Who did you get it done by? Was it a mail order type place? Ive looked around here but cant find anywhere that will restore and balance them!
09-07-2013, 06:28 PM
local company in whitley bay did them mate there is services on ebay not sure how good they are.
So with nothing to do at the weekend I thought I would get cracking tyding up
Bit of a tidy of inside boot floor Side skirts removed rust treated with hydrate 80, etch primer,seam sealer, black hameright Rear arches gave the same process Also gave the underside a bit of love same process as above I also found this down the fair on sunday those under 30 will have no idea what movie its from lol Exhaust off today & follow on the process working my way forward
15-07-2013, 12:24 PM
I've done the under side and rear arches like you have. I need to do the sills though before I put the side skirts on
Project refresh - Silver Hdi Hatchback | DavyCookie | 18 | 5,317 |
03-09-2016, 06:52 PM Last Post: MY95 |
