Cambelt locking tools.
As above what sort of kit would I need to do the cambelt?
http://www.ebay.co.uk/itm/Laser-Camshaft...0714260481
Would this do or is this just pissing money up the wall?
Cheers in advance for any help.
Just use M8 bolts.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
That wouldn't fit an XUD9 I don't think anyway, the holes are threaded.
As pointed out, just use some M8 bolts and a 6mm allen key!
(20-02-2013, 12:45 PM)Ruan Wrote: That wouldn't fit an XUD9 I don't think anyway, the holes are threaded.
what length of M8 bolts is best???
As long as you screw them in correctly and make sure that you know about the cambelt having to be tense from the front when you place the cambelt over the pump pulley and cam pulley, you can just use the intercooler bolts...
I know some people will moan at saying that as it is easy if you're not careful to end up with the timing a tooth out, but as long as you ensure you YANK the cambelt up from the front of the engine and push the pulley all the way on the bolt, and it'll sit in the right groove, and you're fine...
(20-02-2013, 12:58 PM)Ruan Wrote: As long as you screw them in correctly and make sure that you know about the cambelt having to be tense from the front when you place the cambelt over the pump pulley and cam pulley, you can just use the intercooler bolts...
I'm sure I'll be asking for your help in a month or to when the belts being done.
I got mine a tooth out didn't do any harm, glad I had some assistance at the time though Smile
[Image: signiture.jpg]
(20-02-2013, 01:16 PM)kernow_joe Wrote: I got mine a tooth out didn't do any harm, glad I had some assistance at the time though Smile
I will be on my own and it will be my first time doing a belt Confused
As long as you're aware of the possible issue, you'll be fine.
An XUD cambelt is very easy to do, long as you're man enough to get the tensioner off and lock it back, it's an easy job really...
Just be aware there's not much room down the sides, so be prepared for scraped hands!
Just tippex the cambelt and then you definitely cannot go wrong!
I broke my timing belt virginity on my own on a hdi and it was really straight forward just lock it all up and you'll be fine.
Like others have said though it is really tight down there Blush
[Image: ForumSignature.jpg]
Hardest part is getting the cambelt covers off
Just use the 3 intercooler bolts
HDi Cabby Project Click
I use 3 m8 bolts with a bit of tape around the side next tbe head of tbe stud, just to keep tbe injector pump sprocket tight, and made up a pin for the flywheel, its an odd size.
  Parts and Tools for Engine Swap? bigcheez2k3 9 7,744 19-02-2016, 07:33 PM
Last Post: Toms306
  Clutch tools Ben 15 8,659 02-12-2012, 10:53 PM
Last Post: Curt
