20-09-2015, 06:39 PM
Any tips on slackening the bottom bolt that holds the pump to the bracket
Bosch pump to bracket bottom bolt
20-09-2015, 06:44 PM
You ideally need a half moon spanner, but it can be done with a cut down 13mm
20-09-2015, 06:45 PM
(This post was last modified: 20-09-2015, 06:46 PM by bashbarnard.)
If you haven't got a c spanner. (I bought onto to do it on mine) then alternator belt off. Remove the 13mm top alternator bolt then slacken the bottom one and tilt forward. Super easy access then. However if your XUD has pas on the top I feel sorry for you and I have no advice
20-09-2015, 07:00 PM
(This post was last modified: 20-09-2015, 07:01 PM by blinkyeatu.)
Achh balls I've taken to removing the bracket just working on the back bolt fraction by fraction how mimportant is it that I use a new cam belt cause I've only just put this one on and really don't want to have to do the whole thing again
FYI I do have power steering that's what was doing me in
28-09-2015, 04:49 PM
(This post was last modified: 28-09-2015, 10:33 PM by blinkyeatu.)
On the bracket are the studs meant to be in the more adv or regard postion
30-09-2015, 06:48 PM
If I understand you properly, the Adv position.
| Slack in bosch pump? | dt_ | 14 | 12,097 |
21-10-2020, 03:41 AM Last Post: dt_ |
| Bosch pump help for newbie | PugRy | 2 | 4,558 |
05-01-2020, 09:09 PM Last Post: jamie182 |
| Bosch pump fuel screw broken | Forby | 0 | 3,158 |
12-03-2019, 06:47 PM Last Post: Forby |
