Clunk from drivers side
Im getting a clunk from the front drivers side wheel.
This happens when cornering or when loading and unloading the wheel
I'm assuming its a bushing but not sure what one.
Drop link?
Droplink would usually be up and down play, like when going over bumps. Sounds to me like either bottom ball joint or wishbone bushes. Could also be an engine mount though, bottom or drivers side could both sound like they are coming from the wheel area but theyre not.
I tought loading and unloading would of been an up and down motion.
D@wson Wrote:I tought loading and unloading would of been an up and down motion.
i mean for example when you turn left and the weight is on the right and when i brake or slow down for a corner.
Possibly arb bushes..? Only way you'll find out is to get in there and have a look to see if the bushes are perished, it's not like you need to take anything apart to have a look, so get on it. Tongue
yeh get a lil crowbar or similar and have a poke around of the bushes and see what ones have too much play
are they easy to change?
  drivers side engine mount problem 1.9 dturbo xluhxzy 3 4,190 10-04-2019, 07:45 PM
Last Post: Mighty306
  Drivers side driveshaft bearing stuck HDIkyle 4 4,502 17-02-2014, 05:09 PM
Last Post: Danny2009
  clunk knocking sound Whodafunk 28 14,644 07-01-2014, 11:49 AM
Last Post: Whodafunk
